Will these tires work?
Check with TireRack to be sure.
Wheel sizes? 7.5" or 8" in front?
I think 8.5" or 9" is suggested for 245's in front.
I think you mean 285/30x18 for rears? These will fit fine on the standard 10" wheels.
Loren (99 996)
Loren (99 996)
[quote]Originally posted by C2P996:
<strong>I have a 2000 C2 996. Will 285/35x18 & 245/40x18 fit on this car?</strong><hr></blockquote>
If you have factory wheels, chances are the fronts are 7.5" wide. In this case, I wouldn't install a 245 on them. The stock 225 size is the most you should have. The 285 will fit the factory 10" wheel, however. At any rate, these two tires have a larger diameter than the factory specified sizes and will affect your speedometer reading and gear ratios.
Hi Viken. Hope everything is well!! I plan someday to change my rims and tires but with reference to what you said about speedometer reading and gear ratio changes- I plan to have 18 by 10 rear(285's) and 18 by 8 front(225's-that's stock size rt?)-would that affect speedometer and gear ratio? Also with 19 inch rims-any recommendations for install or problems with 19's? Thanks. Mike
[quote]Originally posted by 996FLT6:
<strong>Hi Viken. Hope everything is well!! I plan someday to change my rims and tires but with reference to what you said about speedometer reading and gear ratio changes- I plan to have 18 by 10 rear(285's) and 18 by 8 front(225's-that's stock size rt?)-would that affect speedometer and gear ratio? Also with 19 inch rims-any recommendations for install or problems with 19's? Thanks. Mike</strong><hr></blockquote>
Yes, the 18" sizes you've listed are fine. As to 19's, there are several companies that offer 19" wheels which would work on your 996. One, I would feel confident trusting is RUF. I particularly like the new RUF "Chrome Optic" wheels which are a bright silver paint and look really good. Contact Asgar Virgi @ <a href="http://www.weissach.com" target="_blank">Weissach</a> for more details.
You can fit 275 in the front and 305's in the rear if you want. The 245's should work fine with the appropriate wheels.
A friend with a 2002 996 tried an interesting set up this weekend. he has the 17" rims. He put the rears on the front and they fit with a 275 tire without rubbing, so he is going to get another set of rear tires and run the same wheel and tire on all four corners! That should help eliminate the severe understeer this car has exhibited this far.
Greg
Greg
