996 Forum 1999-2005
alignment settings for an 02 cab with PSS9's?
Old 01-12-2006, 08:42 PM
deputydog95
deputydog95's Avatar
Default alignment settings for an 02 cab with PSS9's?
getting my coilovers installed in the 02 C2 cab on saturday.
are there any recommended alignment settings?
Old 01-12-2006, 09:17 PM
wross996tt
wross996tt's Avatar
Preface...this is for FVD PSS9s on a Turbo Cab.
Front: Camber....-30' ; Toe +5'
Rear: Camber...-35' ; Toe +10'
This is not the most aggressive, so you could go more, but wear the tires quick.
Old 01-13-2006, 12:45 PM
SPR
SPR's Avatar
I put mine at -1f, -1.8r with 0 toe front and factory rear. 0 toe creates a nicer turn in although it will not track as well on the freeway. My tirewear is acceptable in the rear- It does wear out the inners, but if you drive it hard enough it will even out. the front have completely even wear.
Old 01-13-2006, 01:25 PM
JimB
JimB's Avatar
Dog,
I would be glad to share the alignment I have on my 02 cab with PSS9s if your are interested. I would say that I have a slightly agressive street setup. Not a track setup. What coilovers are you installing?
Jim
Old 01-13-2006, 05:30 PM
deputydog95
Bilstein PSS9's.
Old 01-13-2006, 06:13 PM
SPR
SPR's Avatar
what setup are you running Jim including bar settings- thanks.
Old 01-14-2006, 12:44 AM
earlyapex
earlyapex's Avatar
F: -1.5 degrees camber, 0 toe, max caster
R. - 2.0 degrees camber, 0 toe
Old 01-14-2006, 02:55 AM
TT Surgeon
TT Surgeon's Avatar
Not sure pss9's are such a great idea on a cab, structural rigidity you know. They wern't exactly designed to be track cars you know. Might be better off withnthe factory recommended RoW 030.
Old 01-14-2006, 08:30 AM
deputydog95
allegedly, the 02's are a lot stiffer than the 3.4 liter model. allegedly. bilstein usa says it okay. no damage to the car, but i may not get the same results as a coupe based on the chassis give. i had the same concerns you bring up, but after talking to bilstein and a few forum members that are running pss9's on cabs with no problems, i decided to go for it. i was told the only potential, and this was a big if, would be running at 10/10's on the track with race slicks. other than that, normal DE events etc, i should be okay.
the row's drop was too lame for me anyway i'm already at a 40 mm front and 35mm drop with my springs. i can't go back up
Old 01-14-2006, 11:19 AM
wross996tt
wross996tt's Avatar
Dog...what is running at 10/10? If you are going to be using PSS9s then the settings go from 1-9 with 1 being the stiffest. I have mine set 3/4 (back/front).
Chris I didn't know the factory "recommended" ROW 030? They didn't.
Old 01-14-2006, 06:18 PM
JimB
JimB's Avatar
Front
Camber -1.1
Caster 8
Toe .07
Rear
Camber -1.6
Toe .15
I sold my extra sway bars to Carlos before I bought this car so I have the stock ones on. This is just my tooling around in car so I don't know if I'll mess with it anymore.
On the other hand, a S/C would be fun.
Jim
Old 01-14-2006, 06:31 PM
LVDell
LVDell's Avatar
wross I think he means 10/10ths as in max limit the car can take on the track. Most of us can really on push these cars around 6 or 7/10ths anyway.
Old 01-14-2006, 10:43 PM
deputydog95
you are correct sir, Mr. LVDell
thanks for the settings guys.
i hate to ask so many questions, but is there a recommended ride height for the pss9's? i know you're not supposed to go too low according to bilstein.
by the way, we got them on today. they're pretty cool. although they settled kind of funny. may have to play with the ride height some more. that's why i need to know what some of you are running. my fronts and rears are between 25.25 and 25.75 right now.
Old 01-14-2006, 11:27 PM
TT Surgeon
TT Surgeon's Avatar
Wros, sorry to differ, but the max they rec on a cab is 030. TT cab is a little different, it can handle a little more.
Old 01-14-2006, 11:54 PM
deputydog95
i thought you could get an x74 for the 02 cabs on... at least that's what a dealer told me.
Quick Reply: alignment settings for an 02 cab with PSS9's?
