996 Forum 1999-2005
RMS 1999 996
Old Jan 3, 2006 | 07:21 PM
AHEDAU's Avatar
AHEDAU
From: London Ontario-My Fleet:86Cab/95Coupe/ 01 Outback H6 VDC/ 01 PathfinderSE/65Beetle(Survivor)
Default RMS 1999 996
Looking at a 996 that has a rear main seal that has some seepage. Apparently its not leaking very much, but I need to budget for it or ask questions.
I've searched the achieves, and threads range from data suggesting to stay away from 996's all together to just driving them with minor leaks and living with it.
I have an 86 3.2 Cab for pleasure use and its never leaked a drop, but I guess I'm spoiled. I'm now looking for a daily driver and hope a 996 will not be a costly mistake.
The 996 has about 30K miles. Any advice would be appreciated.
Old Jan 3, 2006 | 07:30 PM
1999Porsche911's Avatar
1999Porsche911
Seepage (not dripping, but sweating) of the RMS on any car is not uncommon and many do so for all eternity. It is not necessarily a sign that the seal will give out completely or cause any dripping of oil in the future. Check the history of the car to see if the seal has ever been replaced. It is also very common for the oil that leaks from the cam cover on the front side of bank one will find it's way down the engine and drip from the area where the RMS would. I know of 2 cases where the tranny was pulled to replace the RMS and it was bone dry. Turned out the oil was from the top of the engine. This cover (and the one for bank 2) has a habit of leaking and it has an easy fix too.
Old Jan 3, 2006 | 07:59 PM
ElTorrente's Avatar
ElTorrente
An RMS leak isn't too big of a deal.
Just wait until you need your clutch replaced, and have the RMS done at the same time - you'll save lots of money.
Old Jan 3, 2006 | 08:07 PM
AHEDAU's Avatar
AHEDAU
is a PPI really essential?
Old Jan 3, 2006 | 11:18 PM
kilrgt's Avatar
kilrgt
The new RMS fix . seems to be working out real well,
Old Jan 4, 2006 | 12:22 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Find another 996 without any history of a leaking RMS, there are plenty of them out there. You already know this car has a potentially serious $$$ problem so why make it your own?
Old Jan 4, 2006 | 12:52 AM
pl's Avatar
pl
well, what if the car in question is priced right? like 10K below private party.
Old Jan 4, 2006 | 01:30 AM
Vulture996's Avatar
Vulture996
Is that where they change the RMS and the auxilary seal ? That's what's happening to my car this week. Dealership said it wasn't apparent at time of PPI.
Old Jan 4, 2006 | 01:59 AM
Eli K's Avatar
Eli K
I think the latest is the Cayenne seal...
Old Jan 4, 2006 | 02:57 AM
djantlive's Avatar
djantlive
Check RMS history by looking up warranty history and calling local dealers around. If it's a repeat RMS, I'd steer clear. Otherwise, I'd duct 2-3k off of the value. Also, get a PPI to be sure all the leaks are checked out. Other prone failure inclue MAF, coolant tank, manual tranny, rattles.
Old Jan 4, 2006 | 09:41 AM
searching4996's Avatar
searching4996
If it's 10 k below private party value just buy it and put 4k aside for a 4 new rms's!
Old Jan 4, 2006 | 10:18 AM
SteveFromMN's Avatar
SteveFromMN
Any 996 you buy no matter the year might develope a RMS leak. I agree with the guy that said wait till it needs a clutch and replace both at that time. Same labor cost parts are cheap.
Old Jan 4, 2006 | 01:17 PM
Nutbeem's Avatar
Nutbeem
Under 10k? I'm thinking it's going to need a lot more than an RMS fix.
Old Jan 4, 2006 | 01:40 PM
vove's Avatar
vove
I would get a PPI and check the history of the car to see if the RMS is a reoccuring issue. If it checks out then just buy the car and get the RMS fixed. Hope things work out, good luck.
Old Jan 4, 2006 | 03:34 PM
Eli K's Avatar
Eli K
RMS discussions should be against forum rules, seems like we get a post a day..
