Sports Design Wheel Weights *Updated with Pictures!
For those who are curious on how much the Sports Design Wheels weigh,
Front 18X8 25.4LBS
Rear 18X10 29.2LBS
I had the center pieces painted black so before I mounted the tires, I was able to weigh them. I just used our home weighing scale so accuracy I'm guessing is +/- 0.2 lbs
Front 18X8 25.4LBS
Rear 18X10 29.2LBS
Good to know, thanks for the post. I weighed mine with the tires on since I wanted to learn how much more weight I was carrying over my lighweights on track. All I can say is that those darn sport designs are NOT light!
Boy these wheels are heavy! at least compared to some of the aftermarket ones like BBS RS-GTs which are only 22 lbs. But I know they'll take all the bumps, potholes, high speed turns and rumble strips .etc as they are the first GT3 wheels which were battle hardened in Nurburgring by Walter Rohrl
Here's a pix of the wheels after I got the center pieces painted black. I'm really happy I've always love the looks of black wheels!
Originally Posted by LVDell
What did they run ($) to get painted? I will be back in the area in 5-6 months and want to paint my SD's as well.
I seperated the center pieces from the rims myself, with that damn special tool.. "triple square" bit/ 12 point torx, luckily carried at Pep Boys and brought the center pieces to a local paintshop here in Virginia Beach.
I initialy wanted to do powder coating but I am nervous about the heating process so I just opted for painting. I just made sure that I asked for
the paint shop's darkest black and toughest/top quality clearcoat. I also had the same clear coat applied on the lips after I striped the faded/scratched old clear. I then polished them(that needed a lot of elbow grease).
Removed the scratches from the rim lips by sanding the spots with 600 grit paper, and polished the rests starting with 1500 grit and finishing with 2000 grit with plolishing compound to wet the sand paper instead of water. Too much work but rewarding if you're patient. Which is not me
How in the world did you get the bolts back to factory torque spec??????? Everybody I have talked to (including Wheel Enhancement) said they will NOT remove the two pieces and instead mask, etc., since breaking the seal and the bolts are damn near impossible to get back original.
Originally Posted by dallasboats
RSGT's are only 20 lbs in size 18. I think the rears are 21 lbs at the most
If you want to be exact:
Source: http://www.bbs-usa.com go to application guide section
Part / Finish Size ET Wt. (lbs)
RS928 - DBPK 18 x 10 65 22.10
RS928 - DSPK 18 x 10 65 22.10
RS925 - DBPK 18 x 8 50 20.6
RS925 - DSPK 18 x 8 50 20.6
RS927 - DBPK 18 x 8.5 56 21.0
RS927 - DSPK 18 x 8.5 56 21.0
Make sure you have the right "triple square" bits too. You dont want to strip them when you first remove them. Replacement will be a challenge to find but possible.
Car's looking sharp Mike. I love the sport design look, was going to buy a set but bailed out for the kinesis. Im planning to get my kinesis centers painted black in Spring, you know of any local shops? I was thinking about sending them to Eric at Bumperplug to do the job when Im ready.
The shop I used is just a regular auto body paint shop. Very knowledgeable though. I'm not sure if you want to travel that far from DC, but they're down here in Virginia Beach. I'm sure you'll find good ones up there.
Mike, the black wheels look great! They remind me of my old wheels which were black, very aggressive look! Have you thought about polishing the lip? It will make the black centers pop out a little more.
Also, pretty interesting about the weights of the rims. My LM's came in at 22lbs and 24 lbs and they are 19s.
