Subwoofers
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Originally Posted by RJFabCab
That box won't fit in the cab as pictured. No space behind the rear seats. It's all pop-up rollover protection and top.
Did Porsche offer a subwoofer solution for their cabs? I'm really not too keen to change the configuration of the rear seats or rear footwells since I do quite often 'squeeze' people in there.
I think Kilrgt is on to something with this setup. That is the best idea for a sub enclosure yet. Now you need to add another ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Seriously. The back seat is useless. Nobody sits back there. I have the seatbacks folded down 99 percent of the time anyway to use that space as a cargo shelf. That is a great way of taking advantage of unused space and still maintaining some store functionality. Not to mention you could easily make an enclosure for a 10 or 12 sub in there.
Now Kilrgt: What is that sub box made of? wood or fiberglasss?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
My car has a factory sub in the front passenger footwell. It sounds okay, at best. Certainly not what I'm looking for.
With my setup (rear footwells), you can easily remove one or both and put one in the trunk. It just lifts out. It is formed to tuck under the rear seat cushion so it stays put. Given its a sub, you only really need one. Also, these are super high quality subs. They sound excellent and well balanced.
911driver: i've seen your setup on rod's site. i haven't heard them, but the subs are a little small for my taste. you really need a bigger enclosure and driver to get hard hitting bass. but then again, it's all in what you're expecting from a system and what kind of music you listen to. what kind of subs did he put in your enclosure? i can tell you that i definately would need two subs. especially in a cab. one 8" sub would never fly for me. i do like rod's execution for the install. those fiberglass enclosures look very nice. i've had a lot of systems in a lot of different cars. my favorite so far was my GTI with two 12" orion subs. I had around 500 watts RMS going to each sub. It was awesome. You could feel your hair moving when the bass hit
Originally Posted by deputydog95
911driver: i've seen your setup on rod's site. i haven't heard them, but the subs are a little small for my taste. you really need a bigger enclosure and driver to get hard hitting bass. but then again, it's all in what you're expecting from a system and what kind of music you listen to. what kind of subs did he put in your enclosure? i can tell you that i definately would need two subs. especially in a cab. one 8" sub would never fly for me. i do like rod's execution for the install. those fiberglass enclosures look very nice. i've had a lot of systems in a lot of different cars. my favorite so far was my GTI with two 12" orion subs. I had around 500 watts RMS going to each sub. It was awesome. You could feel your hair moving when the bass hit ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The subs are Earthquake 8” and I will go check the amp when I get down to the garage. They won't roll in Oakland, but they sound very balanced, deep and precise. I listen to everything (roaming XM - recognize not the greatest source quality).
The specs on the subs seem to be -
8" cast subwoofer
Dual voice coil 2 x 4-ohm
2" voice coil, aluminum bobin
RMS. Power 300 Watts
45 Oz double stacked magnet
Newbies Hospitality Director
Originally Posted by gota911
Are they actually conscious when you put them back there? If they are, they must be BLOND and don't know any better!
![](http://a3.cpimg.com/image/9F/36/24071583-fcf7-02000180-.jpg)
Super Moderator
Needs More Cowbell
Needs More Cowbell
This is why, when equipped with the Bose option, the floor mats/carpets for a cab are different than those for a coupe .
I suppose you could purchase this assembly from Sunset Imports (cost + 15%) and meet your stated criteria of not modifying the rear seats or rear footwells.
You actually put people back there? Are you some sort of sadist?
Wow. Robyn, you're TT in the sig is looking sweet.
Cheers
Cheers
Thanks RJ, she's coming along. Since the sig pic, PSI 480 and a set of HREs. Take me off the bbq, I'm done.
