Sirius installation on Becker CR220, pt. 2
Okay, so I went to have Sirius installed, but the tech said I needed the Becker AUX/Phne cable 1319.116-279. Can someone confirm? Also, where can I find this cable? Couldn't get much from Google...
Also, the Becker unit does have an Auxilary port, does it not?
And lastly, how do I get to the Auxilary source from the radio after installation is complete?
Thanks again!
Thanks again!
You can buy this cable from Becker directly. Search on this site for the phone number and contact info. It comes with the instruction on how to enable the front panel control for AUX, Once it is enabled you can press S to switch between FM, CD, and AUX... from what I understand, you can either have a AUX or CD Changer, but this is not totally correct. You can have both CD Changer and AUX.
I don't think you can have both a CD changer and an Aux (ipod or Sirius). Only 1 aux input. If you look at the threads on ipod installations everyone seems to say you loose the CD.
