996 Forum 1999-2005
GT3 Side skirt installation question
Old Jun 6, 2003 | 02:15 PM
CAndrew's Avatar
CAndrew
Post GT3 Side skirt installation question
I have received a pair of the GT3 style flared rocker panels, which I intend to install (or have installed) on my '02 996.
The rocker panels come with the retaining hardware to attach to the lower edge of the existing rocker panel, as well as double stick adhesive strips along the inside of the top edge of the side skirts.
I talked to a body shop yesterday and they felt that the adhesive strips often come loose eventually. They also felt that looseness in the attachment of the top edge could lead to water leaking in and collecting underneath the real rocker panel, leading to corrosion (at least in their experience with other car brands).
They propose doing away with the double stick adhesive and instead sealing the top inside edge of the side skirts with a two part epoxy.
Anyone have any experience with this or opinions on this approach?
Thanks. Appreciate any input.
Old Jun 6, 2003 | 02:52 PM
Loren's Avatar
Loren
Post
There is a procedure outlined in a Porsche TSB that uses epoxy and a special cleaner to make them stick better.
I find it very easy to tell a factory (prepared) aerokit car from an aftermarket simply by the fit of the rocker flairs. IMHO this is something you want done right.
Old Jun 6, 2003 | 06:26 PM
CAndrew's Avatar
CAndrew
Post
Loren,
Thanks very much for your response. Sounds like the epoxy is probably the better way to go. The body shop I'm using does a lot of custom show cars so I'm hopeful they can do a good job.
Andy
