996 Forum 1999-2005
Smoking at startup
Old 11-29-2005, 09:38 AM
mitch236
mitch236's Avatar
Default Smoking at startup
I have a friend who has a 2002 996. We track our cars and whenever he starts his car, there are bellows of smoke. I mean alot! There is so much smoke that everyone near clears out. Has anyone else had this problem and if so is there a fix?
Old 11-29-2005, 11:11 AM
nycebo
nycebo's Avatar
Does he have an aftermarket exhaust or catalytic converter?
Old 11-29-2005, 11:46 AM
rideau
rideau's Avatar
Our local Porsche service manager suggested to a "smoker" at our last track day event that he do a cool down lap and then let car idle for a few minutes to avoid this.
Old 11-29-2005, 01:51 PM
harris
harris's Avatar
correct,
but it is not something that you should worry you....
it is normal to have this smoke after hard driving....
Old 11-29-2005, 01:57 PM
Eli at Pelican
Eli at Pelican's Avatar
Does this happen everytime? Or is this a track-reaction?
-Eli
Old 11-29-2005, 02:01 PM
Eli K
Eli K's Avatar
From what I heard it's fairly common for 3.6 liter engines. I'd suggest letting engine idle for 10 secs or so before shutting it off. This let's the oil settle, leaving less of a chance for it to seep past the ring gaps.
Old 11-29-2005, 03:58 PM
mitch236
mitch236's Avatar
The smoke is so heavy that folks come over to see what happened. Cooling down helps a little but still the smoke is very heavy.
Stock car, exhaust and cats.
Seems to happen mostly at the track.
Old 11-29-2005, 05:26 PM
Eli at Pelican
But it happens everytime even not at the track?
-Eli
Old 11-29-2005, 05:44 PM
dadc4s
dadc4s's Avatar
Default Smoking at the track
This happened to me after several sessions at the track, it scared me so much I had the car trailered home by a friend straight to the dealer who could find nothing wrong except an oil level that was too high! I had had the oil changed at the time of the pre-track inspection the the mechanic said that oil sloshed around during hard charging was getting burned at start up, he took a little oil out, problem solved.
When the smoke formed at start up, it was very impressive and drew a crowd over to my car in a hurry! It was whitish-grey but I have never seen it since.
1999Porsche911
1999Porsche911's Avatar
Next time he know this is gong to happen, remove the crankcase ventilation hose before starting it up. See if this drastically reduces the smoke out the pipes.
Old 11-29-2005, 08:18 PM
agio
agio's Avatar
The smoking only occurs during track time...running hard. He says it doesn't happen while driving the streets.
Old 11-29-2005, 08:24 PM
1999Porsche911
Is your friend running that ****ty 0w40 oil? I'm waiting for one of these cars to seize up using that stuff. No way it provides protection when it's temperature is 230F and higher.
Old 11-29-2005, 09:20 PM
LiveNupe
LiveNupe's Avatar
I've had it happen to me a couple of times after running the car hard at the track and not letting the car cool down. The story was the same both times, I pulled off the track to get some space in front of me. Just as i pulled off, the checkered flag went up so I ended up shutting the engine off without a good cool down lap. After the 2nd occurrence, it was burned in my brain to not do that again. I haven't had a problem since.
Old 11-29-2005, 09:27 PM
LiveNupe
LiveNupe's Avatar
BTW,
As with the guys on this board, many of the experienced Porsche guys told me that this is a normal occurrence under the circumstances.
Old 11-29-2005, 09:43 PM
gofor28off
gofor28off's Avatar
I had also experienced this with my '02 at the track. Sounds fairly common, although I did not see any other 996s doing the same thing. Next time I will be sure to idle for 30 seconds or so before shutting down.
Thanks for the info.
Paul.
Quick Reply: Smoking at startup
