PSE Hack/Mod Question?
I have a 2002 C2 with PSE. It still has the auto mute feature that cuts the sound between 25-45 mph. My PSE has the electronics in place, but does not have the switch on the dash. Kind of a stupid installation which came that way from the factory. The only reason I have not finished what someone else had started before I bought the car is I really don't give a damn about making it quiet. My question is, can I just pull the brown plug off of the vacume solenoid in the engine compartment to defeat the auto mute. Would doing so have any effect on anything else? TIA.
Tom L
2002 C2
Tom L
2002 C2
The early 2002 996 PSE factory installations did not include the dash switch to mute to exhaust.
You have a couple of options.
1. Install the dash switch so that you can manually quiet the exhaust.
2. Disconnect the speed sensor wire at the PSE relay to eliminate the 30-45 mph "quiet mode"
3. Disable the PSE vacuum cutout switch by unplugging the electrical connector.
Here is a post in RennTech that explored all of these options.
