More suspension questions
I am considering three options for my 99 996 C2.
1. Adding the Eibach springs to the stock shocks to lower the car a bit and provide hopefully a bit more crisp handling. Have asked a local aftermarket shop whose owner drives a 996 in DE and he said he has just this set up and likes it fine. This is the least expensive option.
2. Purchasing the european 030 kit with shocks and springs. I understand they have adjustable perches and will allow the car to be about 20mm lower. This is the most expensive.
3. Purchasing a Bilstein/Eibach combination offered by FVD. Have visited their web site and reviewed their ad in Excellence. Slightly less expensive than the 030.
This car is primarily a street car with the odd DE event during the year. Want to lower it for aesthetic as well as handling reasons.
Comments?
Comments?
Dont know anything about Eibach springs, most people that go aftermarket go with the H&R coilovers. I went with the ROW 030 setup b/c im a freak about keekping a car as slose to stock as possible. Dropped the car just the right amount and car corners MUCH flatter.
Good friend of mine has the H&R springs only and he drives the wheels off the car at the track. Car is very fast.
Is it the best setup in the world, no. Is it still faster than most cars lap after lap, yes. Is it an improvement from stock, you bet.
Since he is turning the car back, he might be selling the springs.
E. J.
E. J.
I recently had the H&R Coilover kit installed and I love it. Car is a bit lower and stiffer. I bought the kit at TireRack (at a price no one could beat) and had it installed locally.
Look at the Bilstein PSS-9 system, check out www.carnewal.com or Steve Weiner has them at http://www.rennsportsystems.com/~porsche/
Either source is top-notch.
Greg
Greg
Thanks for all of the responses. Question, though. I understand the H&R's drop the car over 1 1/2 inches at each corner while the Eibach and 030 set up drop it just a tad less than an inch. I am not sure I want to go any lower than 1 inch. I am guessing that by doing so I limit my ability to set the car for the track. Any additional thoughts?
Originally posted by STRSHP:
<STRONG>I am considering three options for my 99 996 C2.
Comments?</STRONG>
Comments?</STRONG>
Mike
Keeper of the Truth
If you have a standard suspension, don't lower the car with either H&R or Eibach springs without changing to firmer shocks. You will have some problems one of which is bottoming out. If you already have the US M030, you might be able to use the above springs and you will find that either set will lower the car approximately 1" ± 0.5".
As to the ROW M030, it is not height adjustable and lowers a US 996 ± 20 mm in front and ± 10 mm at rear. IMO, this would be the best compromise if you are going to drive mostly on the streets. Any coilover setup will be firmer riding in case that may be objectionable to you.
The Bilstein PSS9 is not yet available for the 996.
