996 Forum 1999-2005
02 Cab squeeky door jams????
Old 11-02-2005 | 10:51 PM
skipp's Avatar
skipp
Default 02 Cab squeeky door jams????
I just got a Cab. It seems the door seal areas squeek alot. When the windows are up, it's not as bad, but as soon as the windows or top go down it seems that every imperfection in the road will make the doors squeek. It doesn't seem to be inside the door itself, rather where the door meets the rest of the car. Any one else have this problem or a fix?
Also, when I washed the car with a light power spayer, some water seemed to leak in a bit.
Old 11-03-2005 | 12:21 AM
Bob in NY's Avatar
Bob in NY
My cab has lots of squeaks and noises but only when the outside temps dip below 60 degrees. My top doesn't leak though, you may have a problem. The dealers know how to deal with the noise and leaks.
Quick Reply: 02 Cab squeeky door jams????
