Wheel Bearings .......
Yep...left rear went at Watkins Glen two months ago (at about 3100 miles on the odometer), costing me the remaining 2 days at that track.
Right front started to go at Pocono North (I suspect the BIG bump coming out of the infield onto the NASCAR bowl), and was replaced after that event. I've since added this as part of my end-of-day checklist...of course, my '996' rides a little more stiffly than stock....
- Nick
ncamos@bellatlantic.net
Right front started to go at Pocono North (I suspect the BIG bump coming out of the infield onto the NASCAR bowl), and was replaced after that event. I've since added this as part of my end-of-day checklist...of course, my '996' rides a little more stiffly than stock....- Nick
Originally posted by Nick Amos:
[QB]Right front started to go at Pocono North (I suspect the BIG bump coming out of the infield onto the NASCAR bowl), and was replaced after that event. [QB]
Is this type of failure something that you could feel in the handling of the car or just by checking the play in the wheel afterwards?
Karl
The left rear got progressively worse over two consecutive days at Watkins Glen. It began as a single slight "twitch" requiring a small, quick steering correction at speeds above 120 mph (basically up the front straight and just after tracking out on the back straight). I initially mistook it for wind gusts moving the car at high speed. By the end of day two, it had progressed from a twitch to a full-fledged "jump" to one side or the other -- quite exciting, and clearly not the result of wind gusts. When I put the car up on the jacks on the morning of day 3, I was amazed how much play there was with the wheel on the hub. There was no way you could miss it -- it was so bad that the rotor had to be replaced as well due to scoring.
After that experience, I began checking each wheel for free play at the beginning and end of each day. The developing problem on the RF became apparent at the end of day 2 at Pocono, as I was preparing to put the car into the trailer for the trip home. The movement was not really visible, but I could feel it when I pushed/pulled on the tire with the car up on the jacks. I had my mechanic check it out, and he confirmed that the bearing was beginning to go on that corner as well, so we replaced it.
There is a big difference between trying to rock a wheel with a dying or dead bearing vs. trying to rock one with a new bearing -- the new one just won't move at all.
Hope this is helpful.
- Nick
- Nick
Nick:
What's you lap time on both Watkins Glen and Pocono North? Do PSM kicked in at all if equiped?
I have a 2000 996 and tracked my car on both tracks with no problems on the rotor but the rear brake shields were both bent because of heavy use of brakes. I have stock sports suspension.
My (newfound) technique: jack up car, grab wheel at 12:00 and 6:00 (or 9:00 and 3:00 for rears) with heels of hands on the sidewall/rim surface, try like hell to make it click or (worse) rock by alternately pushing with each hand. Also, try to push/pull entire wheel towards/away from centerline of the car.
For me, it's become a 'feel thing' -- now that I know what new bearings feel like (RIGID), I can tell if they're anything less than solid.
Don't know if there's a more precise/ generally accepted technique...anyone else?
As one of the techers at Potomac region, I will weigh in with my 2cents. Our wheel bearing check is just as described in the last message. Get the car in the air and tug on the top and bottom of the tire. 12 and 6 position. There should be absolutely no play in a 996. The older models should have a "click", say 1/16 play. We also grab at 9 and 3 to check steering rack play. As an aside we had a ball joint failure in a mid-70's 911 at Summit last weekend. Something I haven't seen. Ball joints need to be checked as well. Checking involves prying on the ball joint apart to see if you have any movement.
I am not surprised to hear we are not the only ones. As far as the symptoms I have been experiencing with regard to the wheel bearings, the rears began as a rumble that gradually got louder and louder. After a few days at Pocono on the large track and the bowl in particular, I needed a new rear hub as well. As for the front bearing, while at Watkins we began to feel a slight thump, much like a slight flat spot that gradually became more and more pronounced. In our discussions with many and various people this seems to be going more and more toward the brakes and associated heat toasting the grease. Mind you, this is all just at the theory stage based on our car and some of the GT-3 cars currently running in the Club Race series. Please, … all the info we all can get will help.
I had the same problem with my RF wheel bearing. At speed, it was a dull roar then as I turned to the left a thumping became apparent- just like that mentioned in a previous post. As far as I know, my car hasen't been tracked, and the RF wasn't involved with any "curb-checks". (I bought the car with 10k on the odo) It was replaced, the only problem is my pront end feels a little different while diving into corners, like there is a response delay, but than it "jumps" at the corner, making things a little unpredictable. Anybody else notice something similar?
I've only been through 1 wheel bearing in 3 years of club racing so they go out but not that frequently. A symptom that has not been mentioned is having to double pump your brakes. The play from the bad wheel bearing will push back the pads under hard cornering and you need to double pump to make the brakes work. They have to be pretty bad for that though.
If you get the twitching Nick refered to. Espeically if it happens on a straight when you lift to shift gears, check your rear tie rods. This might be the weakest part on a 996. Motorsports finally came out with a stronger version this year. Before that all the cup cars and R/RS/RSRs used the same ones that are in our cars. Teams would have boxes of extras. I went through 4 this summer before switching to the new ones.
Nick, nice car. Where do you race it?
Jim
Jim
