OIL level check on display?
maybe a silly question...does the car check the oil level EVERYTIME you turn the key on? in my book it does not say but says it checks the oil level when you gas up?
thanks
thanks
thanks
thanks
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
I turn on the key but not all the way to crank it just yet until the process is complete. It gives the computer to do all the checks prior to turning the motor.
I give it at least 5 secs with the key in the ON position before craking it all the way to START. I think this gives the computer a surge free uninterupted check of the system.
opening the fuel filler door first!!!
If you turn on the key (but not start the car) whether the car is warm or cold, it'll start the countdown and say it needs something like five minutes to check the oil level. If you open and close the fuel filler door first, then turn the key to on (but not start) - then it'll start a much shorter countdown and take only about 5 seconds to do the oil level check!
I've found that the countdown is based on engine temp and whether the car has been running. I believe it's to allow the oil to drain out of the engine to get the best read. If the engine is cold and hasn't been started, the countdown is short (although you're only supposed to check level on a fully warmed up engine). If the engine was running, the oil has to drain out of the engine, hence a longer countdown. The countdown is cancelled if you start the car before it's finished. The exception is when you gas up, and I think it's assuming that the oil will have drained while you were filling up, so it gives you an instant read with no countdown.
thanks
I learn something new from you guy's every day! I have from time to time seen the level indicator on my 99MY but never really understood how it functioned...or when (and couldn't find it in the manual). Now....thanks to all of you...I am starting to understand how it works and can put it to good use. Thanks!
