996 Forum 1999-2005
How to remove those strips on the dash?
Old 09-15-2005 | 09:43 PM
mc_sahib32's Avatar
mc_sahib32
Default How to remove those strips on the dash?
I need to replace the 3 pieces of strip on the dash for some colored ones. What is the best way to remove them, they are very tight fit.
Old 09-15-2005 | 09:48 PM
kilrgt's Avatar
kilrgt
Well , there are 2 ways to do it, first off do you have the full leather option, or the plastic.Once I know that, i can direct you do the best way to remove these.
Old 09-15-2005 | 09:50 PM
Loren's Avatar
Loren
Removal & Installation of Dash Strips (how to pics)
Old 09-15-2005 | 09:55 PM
kilrgt's Avatar
kilrgt
Ok Loren covered both with one reply.....Man he is good!
Old 09-15-2005 | 10:20 PM
mc_sahib32's Avatar
mc_sahib32
thank you. look like the old strips cannot re-use again?
Old 09-15-2005 | 10:49 PM
smshirk's Avatar
smshirk
Until I read this I thought I wanted to replace my strips. All of a sudden the black looks pretty good
Old 09-16-2005 | 02:33 AM
SANDOVAL's Avatar
SANDOVAL
I used a solder gun method to remove the strips. Take your new set and match the strip up and find out the location of the screws. use a magic marker and dot the location of the screws. The solder gun will go righ through the plastic. It is a 5 min Job. When you attach the new strips I used hot glue to assure a tight secure fit. This is a very simple DIY job.
Good luck.
Old 09-16-2005 | 02:39 AM
Itzkirb's Avatar
Itzkirb
Loren to the rescue!
Old 09-16-2005 | 01:46 PM
LVDell's Avatar
LVDell
I was afraid of the solder iron route as well and just used my own method based on the solder pen instructions. I just started the stip removal at the A/C vent with a scredriver under the strip until it popped up a bit and believe it or not, just pulling it out all the way across was a snap (or shall I say unstrap). Of course, it is not re-usable when you are done but I had the sodler pen NOWHERE near my all leather dash. Not sure if my strips were an anomoly being less difficult to remove with the solder pen method but I was willing to try b/c I realy knew I would screw up my dash.
Old 09-19-2005 | 04:14 AM
Kevin M.'s Avatar
Kevin M.
That Kevin guy is a nut I wouldn't follow his directions
