C4S Wheel hub corrosion
3rd Gear
Hi there,
My C4S with 6000 miles has recently started showing some corrosion on the wheel hub ( not the actual disk- which I know is prone to corrosion).
The car is parked outside (sadly) but I was wondering if anyone else had experienced this...doesn't seem normal to me on such a new car?!!?
Any thoughts would be appreciated
Jon
Jon
Jon, have you been using Wonder Wheels or any other acid based wheel wash - they destroy the coating on the wheel nuts and the hub centres. Drive in "hand" car washes use this gunk all the time and it is too strong! Once they start to corrode it can't be stopped. In my case it was new nuts....
3rd Gear
Thanks for that...sounds the most likely answer actually! Am going down to Porsche this saturday to have it checked out......even so sounds strange to me for such a new car!
