Clear Third Brake Lights
Originally Posted by fasteddie99
How do they install? Do you have to go in from behind or remove the oem one from the outside?
Pretty easy DIY.
Originally Posted by riozilla
I ordered mine from Gert but they have been sitting in the FedEx depot in Memphis for the past 5 days with a "Customs Clearance Delay" and they still have not moved out to me.
Very frustrating but not the fault of Carnewal.
That's a procedure where they try to find out if these parts are for private use or for resell. We have completed the necessary form and the shipment will be released tomorrow.
Member - times 3
Member - times 3
I bought smoked for my seal greay. It is a tad darker than the "clear" sidemarkers which are smoked almost perfectly for the seal grey. So I'm thinking it will be a bit too dark, but the clear would be way too light. I haven't installed it yet so I can't say for sure. There are 16 red LED's, I believe.
Member - times 3
Member - times 3
Originally Posted by neil.schneider
Did you guys all order the clear turn signal bulbs, so you don't get that amber look?
http://www.jamstrait.com/194s.htm
194-HA's work great. I used the HR's in my stock third brake light.
Edit: Oops, I replied before reading thoroughly. You were referring to turn signal bulbs and my reply refers to side marker bulbs. I'll leave my post in case anyone is interested in side marker bulbs.
