yokohama -- ADVAN Neova AD07 -- Any experience here in renn world?
Tire looks bloody sweet. A little more track ready than the so2a's but still not track specific!
http://www.yokohamatire.com/advan/
The ADVAN Neova AD07 is the Max Performance Summer tire member of Yokohama's global family of ADVAN performance tires developed for sports car, sports coupe and performance sedan enthusiasts who love sport driving. Used as Original Equipment (O.E.) on the Lotus Elise, the ADVAN Neova AD07 is designed to provide high levels of traction, responsive handling and driving control in dry and wet road conditions. The ADVAN Neova AD07 is not intended to be driven in cold temperatures or in snow.
Designed to deliver Yokohama's ultimate dry street performance while maintaining good wet traction, the ADVAN Neova AD07 uses a "fine particle" Micro Silica (MS) tread compound (to provide greater road surface adhesion) molded into a directional tread pattern that features massive, rounded tread blocks to increases cornering stability and steering response. Five large circumferential and multiple directionally aligned lateral grooves resist hydroplaning and enhance wet traction. Internally, the two wide steel belts reinforced by spirally wound nylon cap plies and provide excellent strength and uniform ride quality while the sidewalls are tuned to resist lateral deflection to provide handling control and feedback.
Like the motorsports tires this Max Performance street tire has evolved from, the ADVAN Neova AD07 radial's construction and compounds have been tuned to maximize the tire's traction and performance within a specific range of ambient temperatures. Therefore, unlike less highly tuned tires, Yokohama's care instructions specify that due to its compound characteristics, ADVAN Neova must be used and stored at temperatures above -10° Celsius (14° Fahrenheit) to maintain its performance and avoid tire damage.
http://www.tirerack.com/tires/tires....=true&index=10
I have no experience with these "new" Yokos, but ever since they stopped producing the 008, I've been waiting. The 008 was the best tire I ever rode on. I also look forward to hearing from anyone with first hand knowledge of this tire.
