996 Forum 1999-2005
turbo twist wheels
Old 06-22-2005 | 05:28 PM
Midnight Rider's Avatar
Midnight Rider
Default turbo twist wheels
did the 99s come with an option of the 18inch turbo twists? If so, were they the same 18inch turbo twist wheel that was an option on the 993?
Old 06-22-2005 | 06:18 PM
Eric - Plug Guy's Avatar
Eric - Plug Guy
Basic Sponsor
I had a '99 996 C2Cab with optional 18" turbo look wheels straight from the factory.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old 06-22-2005 | 08:16 PM
jetskied's Avatar
jetskied
My 2001 has the wheels and the part numbers are 993 ones. So the answer is yes.
Old 06-23-2005 | 12:44 AM
lexpilot's Avatar
lexpilot
I do not believe that the 18" wheels were available on 993. I had 17" turbo twists on my 993. They are the same as the standard wheels on a 996. 993 came with 16" cup wheels standard. See my avatar for stock 18 turbo look wheels.
Old 06-23-2005 | 01:45 AM
arenared's Avatar
arenared
Numbers for all the factory Turbo Look wheels that I could find were all 993.x.x.x numbers and only in 18". There are various widths/offsets and some were options on the 996 and Boxsters. The "Turbo Twists" were only 17" and (also?) came on the 996 and Boxsters. lexpilot's avatar shows the 18" Turbo Look wheels. Do you mean those instead of the Turbo Twist? I think the Turbo Twists were also known as the Boxster Design wheels on Boxsters.
Old 06-23-2005 | 02:04 AM
lexpilot's Avatar
lexpilot
Further investigation leads me to believe that my 18" turbo look wheels were available on wide body 993S and 993 4S models as an option. 17 inchers were standard on the 993S. Turbo models were on 18" wheels that had hollow spokes for reduced weight. A hollow spoke wheel weighed 30% less than standard spoke. 7# for an 8J x 18 wheel.
Old 06-23-2005 | 04:26 AM
Rob in WA's Avatar
Rob in WA
Cap'n Insane the Engorged
They're also known as "Technology" wheels.
On my MY01 they were a $1,190 option and listed as 18" Light Alloy Turbo Look Wheels.
Old 03-08-2007 | 06:35 PM
Martin S.'s Avatar
Martin S.
Default Thet were ordered on my car (993 NB)
I have the option sheet somewhere...
Old 03-08-2007 | 06:55 PM
hwk72's Avatar
hwk72
They are just terrible heavy!
Old 03-08-2007 | 07:45 PM
Porsche_Smile's Avatar
Porsche_Smile
they are heavy....... but they do come as an option....
Old 03-08-2007 | 08:19 PM
Martin S.'s Avatar
Martin S.
Yeah, and they are not BBS 3 piece racing wheels.....but they are about 1/3 the cost. Also note, the hollow spoke technology wheels are about 5 Lbs lighter than the solid spoke Turbo-look wheels. You gets what you pay for.
Here are the part numbers and weights of both wheel types.
Hollow Spoke "Technology" wheels:
993.362.136.00 - ET52 - 19.95 lb (front)
993.362.140.01 - ET65 - 23.36 lb (narrow body rear)
993.362.140.00 - ET40 - 25.13 lb (wide body rear)
Solid Spoke Turbolook wheels:
993.362.136.01 - ET52 - 25.57 lb (front)
993.362.140.04 - ET65 - 29.32 lb (narrow body rear)
993.362.140.03 - ET40 - 31.08 lb (wide body rear)
