rolling fenders clarification please
can someone please describe to me what rolling fenders actaually is...i understand the basic concept of lowering the car and moving the wheel well space outward but how is this done? thanks
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Pretty simple. If you were to take a cross section of your fender lip you would see it looks like an "L". Run your fingers along the inside of the lip and you will feel it. This is done to make the fenders stonger. Rolling the fender is nothing more than pushing the bottom part of the L up against the top. Bending the part of the lip that extends towards the tire up so that it lays flat against the inside of the fender well. This gives you more room for tires. The downside is a significantly weaker fender.
You can do this a number of ways. Someone (BK?) makes a tool but most use a bar or a bat and a hammer. You jack the car up, stick the bar or bat between the fender and the tire and slowly let it down. You can then roll the bar along the tire bending up the fender lip as you go.
WARNING - it is very easy to crack your paint or mess up your fender. Don't do this unless you know what you are doing or are willing to risk a trip to the body shop.
Jim
Jim
Never did it on a p-car. There is a lip on the fender facing the wheel. On the spec RX-7's we'd just fold them into the inside of the fender with a baseball bat...
It is a modification where the fenders are mechanically flared to accomodate a wider tire track. They have a tool you can rent, or old school is rolling a bat inside the fender well until the desired flare is attained. Suggest having it professionally done if it sounds like something you want to do.
I second or third the "have a pro do it". If you are looking for room underneath, I am running 285's, a 15mm spacer, -2.5 deg camber, my car is 24.75" and I have no rub issues, plenty of room. The tool they use monts to the hub with a urethane roller to do the rolling. Search online for a pic. They are pricey.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Your tires would be an inch bigger in diameter. If you want the same diameter you'd have to go to a 245 30 19, which will be narrower. You would have less sidewall between your wheel and your nasty montreal bumps.
yeah slap on those 19s
But make sure a professional does your rolling. I would never consider it as a DIY project. Especially on your 996. Good luck and let us know how it goes
no can do....really wany 19......how come the new 997 comes with either 18 or 19 and the 19 is 285-30-19...... and 285-30-18???
I'm sure you can make it work well enough for the street.
does that just mean the speed will be off? i can live with that...but will it mess something else up like the differential or something like that? thanks
hmmmm got me thinking now....anyone have any hot 18's to sell?spedning money on headers mufflers etc...so looking for a deal...just finished with the mods on my new cayenne s....if i can figure out how to post pictures i will some day...looks hot....
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
