Backfire!
Newbies Hospitality Director
Originally Posted by Superfans
Does anyone know how to fix a backfire problem which happens on deceleration?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Are you using the engine for braking? Are you blipping the throttle to match revs prior to letting out the clutch? This can cause a backfire if you spin the engine to high rpm's with little or no throttle. A leak as 99 911 said could also be the culprit.
Mechanic found an exhaust leak and fixed it. But there is still a little bit of popping. I've found some articles on the web which said that popping on deceleration could be caused by a faulty air injection diverter valve. What do you think? Is there an air injection diverter valve in the 996?
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Originally Posted by gota911
This is a Porsche!... NEVER decelerate! ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
this was a great thread; laughed more than in the first part of jumping between letterman and the other guy.
[QUOTE="...Are you blipping the throttle to match revs prior to letting out the clutch? This can cause a backfire if you spin the engine to high rpm's with little or no throttle..."
I blip the thottle to match revs but never enough to cause a backfire...how or why would an over rev cause a backfire...just curious?
Jim
Jim
