Where to get PCM Codes
I bought a second hand PCM1 off ebay and has just been fitted.
unfortunately i did not get the PCM codes and the seller does not have, although he does have the chassis number of the car
Anyone know where I may get these.
Dont think my local porsche center wil be too helpful
Good luck. You probably just bought yourself a stolen PCM. The whole point of the codes is to prevent people in your position from getting the code in order to deter thefts. Why on earth would the seller not have the code? How did the seller get the PCM? If you can prove clear title to the PCM, then you should be able to call a dealer with the proper info and get the codes? Even without clear title, a careless dealer could probably get it for you. Never buy a porsche stereo without codes: you probably just helped a thief.
