oil change = 10qts?
'99 C2, oil filter and oil change in my car is always 10qts. The owners manual say 9qts. (9.2 or something... I don't remember exactly).
With 10qts. the dipstick is right at full and not a drop above. Does the car really take 10qts?
This is my 3rd oil change and I keep forgetting to ask about this.
Range Master
Pepsie Lite
Pepsie Lite
That is what mine takes (If I let it drain for a while). I think that it takes some time for the oil in the cooler and lines to drain back. I usually am not in a hurry when I do this and once even let it sit for a week, because I had the wrong filter. I put an empty coffee can in place to catch the drips, and when I went back to my shop a week later the can was overflowed.......I was quite surprised. She took every bit of 10 quarts to refill.
Range Master
Pepsie Lite
Pepsie Lite
An hour is the recommended length of time if I remember correctly, However, I got a more than 1/2 a quart more to drain out by letting is sit for several hours. Maybe the op has a car that drains easier....who knows......
Originally Posted by 1999Porsche911
Higher than mine takes. What does the electronic gauge show? I use 9 with filter change.
Anyone know if there is a visual way to verify this or is it just an internal mod and the outside looks no different?
I know he did a lot of D.E.'s so maybe that's why it take more oil?
BTW -> I let the oil drain for about an hour everytime I do this.
I put in the amount suggested in the DIY on renntech. Drove it around for while and checked the oil and then added a little. I was really concerned about overfilling.
You know I'm really intrigued by just what your company car is...
Originally Posted by leedav
Assuming you let everything drain for a couple of hours, what is the refill procedure? Do I add 9, run it for a few minutes and then check?
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Originally Posted by Ekename
Good point Nick.
Originally Posted by NickS
BTW... when you gonna call me to detail the P-car? I am just down the street. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Soon. Need to get some prices from you too. See what I can afford ![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
nsnyder996@yahoo.com
