How often do you change your oil?
My 996 TT has over 200'000km (124'000 miles), and I've changed the oil every 20'000km (12'400 miles). If PAG says it's the way to do it, why do it more often? Do you change your brake pads when they're half-thick? ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Greetings,
--Pierre
Greetings,
--Pierre
IMHO oil change intervals are dependant on the type of driving you'll been
doing and the mileage you'll accumulate. I.E. if you drive long distance
computes, for instance 50 miles each way at freeway speeds, then changing
oil at 15K is fine, but if your driving is short trips at varying speeds(stop &
go) then you'll need to change the oil more often. The general rule of
thumb is change the oil at least once a year if you don't reach the
factory recomended interval.
I change my oil every fall just before I put it away for the winter. I put about 5K miles a year on the car. It is probably overkill but it is easier to change oil than engines. Remember Porsche only needs to get past the warrenty period I intend to keep my car probaly 10 years. YMMV
i have the dealer do it, usually the car sits there overnight, i always get a porsche loaner.
about 300$ each time.
im consumed with other things to change my own oil...
i only let the dealer touch my car.
it also depends on weather conditions...
Pierre's car ( in fact photos of the car) were taken at a -7 degrees clcius.....and of course this temperature has nothing to do with Dubai's temp,......
i.e oil change intervals , will be shorter at higher temps countries....
Here is my personal philosophy with reagrds to oil. If I run my car hard (which I tend to do) I change the oil, at the most, every 5000 miles. If I have a DE or Track weekend, I change it when I return. Simple preventive medicine. Oil is the life blood of the engine. Changing it often is not a bad thing at all. Just my .02.
Chad
Chad
