Seat Belt Harness help needed please
I am wondering what most of you have done in the way of harnesses for track use. The purpose of these would be to keep me better planted at track days. WIth the stock seats and belts, I find the stock seats almost useless at times.
I am looking at the following:
Objectives:
1- four point harnesses (prefer 2" over 3")
2- some kind of harness guide bar behind the seats (I actually bought one from a company last year who claimed that it will work for tall drivers and learned that I would have to move my seat forward four inches)
3- mounting the rear of the belts to factory belt or rear seat locations with a way to unclip them easily if possible
Restrictions:
1- I am using factory sport seats and do not want to go to GT3 or aftermarket seats
2- I have the Bose subwoofer enclosure behind the rear seats
3- I need to rewtain access to the rear seats (OEM tequipment bar not possible then)
4- I am tall, fat (and some say ugly too) and keep my seat back at the notch farthest back although I drive fairly straight-up with little recline
5- I am not too smart
6- I have dumb friends
I have seen the following Brey Krause accessories that could help:
1- Inner tunnel seat harness mounts
2- Outer seat harness mounts
3- Rear harness mount that will not work with Bose and does not allow use of the rear seat (not good for me)
Other stuff:
1- I also saw a picture of someone's car that had an OEM Porsche Panamerica roll bar (no cross or diagonal bars) and he welded a cross bar at the very back, between the two support bars, not the main hoop, allowing it to be used for harness mounting without sacrificing the back seat.
Any input or information would be greatly appreciated. Dumb comments, criticism or thrashing are just as welcome but less productive and helpful to my cause.
Thanks in advance.
P.S. I will trade one single loaf of my wife's world-famous Banana Bread for a good, useful solution
Objectives:
Restrictions:
Other stuff:
Thanks in advance.
I think your Bose in the back is your challenge.......focus on that.....everything else is no problem.
Call Brey......see what they say on the Bose.
By "OEM Porsche Panamerica" I assume you mean Techquipment......be aware that that roll bar (whether with or with-out cross member) does impead 'full' backward movement of stock seats....may or may not be an issue for you.
Good luck to ya
Good luck to ya
I was told that the Tequipment bar (that Panareica bar) did not impede movement of the seats (except for extreme recline). Does anyone know if a simple harness guide bar can be purchased for the 996 coupe? I only need it to guide the belts so I can attach them at the rear seatbelt mounting spots. The one I bought was from Stable Energies and was told that it would not interfere with the front seats but they are clearly wrong. Really, a guide bar and some of the Brey Krause inner and outer mounts would probably do the trick...
Alon, I did a lot of research on this subject a bit less than two years ago. The complete Brey-Krause system of R-1035 harness mount for the shoulder straps and the R-9001, R9003 for the belt and sub-belt mount is currently the only acceptable hardware for a 6 point belt system for stock sport seats on a 996. And you must use a 6 pt. system, not a 4 pt. Even this is a compromise and in some people's opinion unsafe because of the possibility of the shoulder straps slipping off your shoulders. However, it's what I and several others on this board have and most people who know about harness systems believe it to be safe. But no one would say that even this system is optimal.
However, if you start changing the angle the shoulder straps from where they meet your shoulders, and possibly the width of their mount points, and the length of those straps, then you are in uncharted territory. I have learned that you can kill yourself very quickly in a minor collision with a badly designed harness system.
Sorry to be so pessimistic, but with your restrictions you're better off with the stock seat belts.
I don't consider you as being pessimistic and your feedback is much appreciated. I guess that at the end of the day, I'll probably end up with a proven setup using the seats and proper bar or just staying with the street setup for now.
Thanks again.
Thanks again.
Check stable energies, stableenergies.com -- I got their B-pillar harness bar but I believe they also have a C-pillar bar for the 996. The B-pillar would not work for you because the seat would be too far up.
With this setup, use the BK inside mount, and then install an eyebolt in the outer seat belt mounting point, and in the rear seat belt mounts for the shoulder straps. You can then get a dual sub-strap and bolt them on to the front seat mounting bolts. You don't need an outer mount from BK.
With this setup (this is exactly how mine is done, except for the b-pillar bar) you retain the Bose speakerbox because nothing mounts to the rear struts.
I obsessed long and hard over this issue, then at a DE with only one car involved there was a rollover where the driver, while hanging upside down, had to be cut out of the car. He was OK due to a roll bar and full harness. I decided that I would get a cage and 6 point harness. I am having a bolt-in cage with welded attachment points put in. The front part of the cage can be removed separately from the back cage. I'm using GT3 seats because they, along with the bar for the harness, will put the harness at the right angle to protect me. I've also purchased a Hans device to protect my neck. Overreaction, maybe, but I've seen what can happen and I just want to have fun and stay safe.
I obsessed about this stuff for a long long time also. What it comes down to is that short of installing a cage (obviously the best solution) you have to figure out what you feel is a good compromise. I wasn't thrilled about having harnesses with no roll-over protection, but on these cars (and most modern carss) it seems like the a-pillar collapses, not the b-pillar, in most instances. If the b-pillar collapses, only the cage (not the roll bar) is going to save your life, but that isn't very likely to happen. The only way to be 100% safe, however, is to stay off the track.
And on the street, the cage/bar is a hazard to your safety. I think you are probably more likely to get hurt on the street with a cage/roll bar than you are on the track without one. In my case, I also couldn't give up my rear seat because my son sits there.
Alon - Sparco makes a nice harnes bar that bolts in. Harnes mounts behind seats and allows for proper spacing of harness belts. I installed in my 996, only to decide that I'm going to go racing so I'll hve to go wth rollbar/cage. PM me if you want to know more.
Thanks everyone for the great info. As far as Stable Energies, they are the ones who sold me that B-Pillar bar and I didn;t know that a C-Pillar bar even exists. I'll go and check. As far as the Sparco harness bar/guide, do you have any pictures and/or more information on it?
Pocket Sand
its basically exactly the same as the brey krauss harness GUIDE bar with two supports that connect to the lower front seatbelt mounting points. Doesn't look too sturdy compared to some others imo. Good luck getting one too, my local shop had me wait for 3 months onlyto tell me they havn't been made yet.
