Alignment Specs.....
I have just installed a set of H&R springs on my 04 C2. I realize I need to have an alignment done. Does the installation of these springs change the alignment specs from the factory settings. Car is an almost daily driver with a few pending DE events. Thanks in advance.....
The specs for your car wills stay the same however the "window of adjustment" will be shifted one way.Usually your car will have more negative camber when lowered which usually can be corrected in most cases. Id definately get it aligned soon or else youll be replacing tires sooner then you want to.
