996 Forum 1999-2005
Clean Exhaust tips
Old Oct 24, 2004 | 07:19 PM
Chrisp3's Avatar
Chrisp3
Default Clean Exhaust tips
This has probably been discussed before (am please forgive me if it has) but does anyone know what can be used to clean and polish the OEM exhaust tips? My 99 C2 was not as pampered in its former life as I would have liked and the tips are discolored from heat and lack of attention.
Any suggestions on how I might get them looking good again?
Old Oct 24, 2004 | 07:46 PM
TT Gasman's Avatar
TT Gasman
Try some "000" or "0000" steel wool and some metal polish and they will look good.
Old Oct 24, 2004 | 08:01 PM
Arthur's Avatar
Arthur
Bar Keeper's Friend: Cheap. Cheap. Cheap. Apply with soft moist rag. Old T shirt will be fine.
Any kind of metal polish in a paste form. Meguir's makes one I think.
Easy with the steel wool, don't use the stuff we clean barbeque grills with. Get the one Eagle makes, available at your local Walmart.
The Best I've used is made by MAAS. I got it at the grocery store. Tube paste. http://www.alwaysbrilliant.com/?PID=...20Polish%20all
Old Oct 24, 2004 | 09:59 PM
Poursha's Avatar
Poursha
I use P21S Multi-Surface Finish Restorer Polish:
http://www.carcareonline.com/detail....oduct_id=10417
Use part of an old tshirt, rub well and buff off, then repeat. After the first time, it's a lot easier.
To keep the gunk and yellowing down to a minimum, I use RejeX:
http://www.corrosionx.com/rejex.html
It works great on exhaust tips, wheels and windshields, for keeping stuff from sticking.
Old Oct 25, 2004 | 02:55 AM
ADias's Avatar
ADias
The stainless steel tips can be cleaned w/ a a 3M pad but they are not supposed to be shiny - just a dull smooth finish - that is the look of a properly used hot exhaust tip - anything other than that is girlie man stuff
Old Oct 25, 2004 | 08:39 AM
Chrisp3's Avatar
Chrisp3
Thanks much for all your comments. Amongst all of these suggestions, I should be able to find a suitable product to get them clean....and keep them clean.
Old Oct 25, 2004 | 01:04 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
I tried all sorts of stuff, including a significant amount of elbow grease.....nothing worked, until I tried some powdered "copper cleaner" stuff for kitchen pots and pans.....even Comit didn't work, but this copper cleaning stuff worked immediately and did a nice job of cleaning up the tips. Now I have my own supply, courtesy of my bride.....
Old Oct 25, 2004 | 07:47 PM
Thegman's Avatar
Thegman
I sent my tips (2003 Targa) out for a machine polish. They look almost like chrome now. I keep them up with MAAS metal polish. They always look great.
Old Oct 25, 2004 | 08:12 PM
Orient Express's Avatar
Orient Express
I took my tips off and buffed them up on my bench grinder/polisher. It took about a hour to buff the stainless up to look like chrome. I use a medium buffing rouge (red) and finish up with a metal polish like Autosol or Mothers. To keep the tips from turning brown, I coat them with Rejex.
Old Oct 25, 2004 | 08:55 PM
Kompressor's Avatar
Kompressor
0000 superfine steel wool and windex. any liquid acts as a lubricant and prevenets scratching if the wool is fine enough
Old Oct 26, 2004 | 01:56 AM
SPR's Avatar
SPR
I use wax and it works just fine but I have the chrome optional large ovals.
Old Oct 26, 2004 | 03:41 AM
Itzkirb's Avatar
Itzkirb
here are mine...
Metal Polish from Kragen...5 minutes
Rejex'd...5 Minutes
Super big close up Shot Click Here!
Old Oct 26, 2004 | 01:26 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
New meaning to the term "show us your tips".......??
Originally Posted by Itzkirb
here are mine...
Rejex'd...5 Minutes
