Tire pressure 36f 44r
Tried this according to the book and it made a huge difference in handling. Anyone else use these inflation levels?
Keeper of the Truth
Originally Posted by DJ 996
Drop them to 34f/39r, the factory GT3(mk1) spec., feels much better.
Keeper of the Truth
Originally Posted by c70Pete
Interesting...
what is the optimal pressures on a 996 with 17" rims...?
Thanks for the info Viken... I know this has been debated many times... but if I wanted to use tire pressure to dial in more oversteer or understeer how does one do this.... ?
Keeper of the Truth
I had 35 in both and recent temp drops in the NE brought them to the high 20's. I should have checked my tire pressure more often. So for a week I was driving on 27lbs of pressure! Warning to people living in the MW or NE , big temperature drops really effect tire pressure.
To C4S owners: Do you stick with the 36/44 recommendation? I have been. If you don't what differences do you notice?
I would say that my car is quite skittish at times on pavement with some grooves in it.
Can this be corrected with different tire pressures, or is it normal.
no "bumping" on mine at the higher pressure levels, although a firmer ride but more stable at speed.
