Rejex Rocks!!!!!!!!
Originally Posted by spar10
can rejex be applied with an orbital polisher or does it have to be applied by hand? if an orbital would work, would you just use a polishing pad? thanks!
fyi - I've posted my pics and comments about Rejex. Great product!
https://rennlist.com/forums/showthre...=1#post1669306
Originally Posted by C4SSurgeon
Will it do anthing for swirl marks?
I have applied Rejex with a PC buffer and by hand. I have noticed nothing different. You use more doing it the PC way but it is not that expensive
I also use a leaf blower to dry my cars and this stuff lets the water blow off with ease.
This kind of shine impresses everyone......
RejeX is still $16.09 and $2 for standard shipping.... it's the rennlist discount. be sure to use the new RejeX discount ordering page. it's fast and easy. here's the link....
http://www.x-autoproducts.com/pages/forumpurchase.htm
Originally Posted by Orient Express
No not really, but AFTER you have given your car a coat of Rejex, and it has cured, then go over the car with some Meguires Swirl Remover 2.0, and you car will look marvelous.
I couldn't disagree more. The Rejex is the LAST thing you do. Any polishing, swirl removing, stripping, etc... should be done first. Any abrasives used (swirl removers contain abrasives) will remove the Rejex. And again, make sure the products you use before Rejex do not contain any silicones as that will inhibit the adhesion of the Rejex.
Wash with Dawn
Clay bar car to remove impurities
perform any polishing or swirl remover required
If any of the polishing products contain silicones, rewash with Dawn to strip it
Apply Rejex with car cooled down in the shade and buff
Allow car to sit 12 hours out of sunlight to cure, rebuff if necessary
Ejoy!
