Racing suspension-which one?
https://rennlist.com/forums/showthre...s&pagenumber=2
https://rennlist.com/forums/showthre...&pagenumber=11
https://rennlist.com/forums/showthre...hreadid=124536
http://www.6speedonline.com/forums/s...d&pagenumber=2
Good Luck !
The X-74 will not be adjustable.
Will your car be turned into a track specific car? Will you be willing to sacrifice comfort for handling on the race track? What's your budget? Do you know what class you want to run in (the rules may dictate your suspension choices)?
One very easy way to get to where you want is to attend several races and see what the top drivers are using. Find a good Porsche race shop and have them work with you and your driving style to dial in your suspension.
PSS9s - Street use with occasional track events
JIC Cross - Street use with more aggressive track use
Moton - Track use with occasional street
JRZ & Fox - Track use only
George
Akkurat Performance Group, Inc.
Great point about class rules regulating suspension set ups. Budget is 4000.00 for suspension which includes the coilovers, swaybars and misc. camber plates, etc.
George could you tell me more about the Moton. I know the Cross has three race spring rate set ups. A friend is running the middle set up and likes it on the track. Another friend is running JRZ on track and street. Very fast on the track, hard on street, which is ok, but has replaced all four units at least once. Any opinions on sway bars? Thanks again
