996 Forum 1999-2005
996 SAI Emissions Check
Old Jun 7, 2026 | 08:38 PM
Dave Crellin's Avatar
Dave Crellin
Default 996 SAI Emissions Check
Having just completed an engine rebuild on our 996 (LN Engineering Nickies after buying with a cracked cylinder) the car runs absolutely wonderfully. Couldn't be happier with the result. However, it needs a smog check to take it off NonOp status, and it will not clear the SAI cycle check. Here's what I know:
The air pump works, blows plenty of air from cold start for the right amount of time (about 90-120 seconds).
There is no check engine light
The O2 sensor voltages behave exactly as they should during the cold start SAI cycle as described in other threads here on Rennlist
All other emissions test cycles are ready except for the EVAP one that is not necessary here in California.
I've done three drive cycles all with the same result
Tomorrow I'm going to a guy I know that has a PWIS to see if that might give more clues than I can see but in the meantime....
Any ideas from the collective experience?
Old Jun 7, 2026 | 08:47 PM
Porschetech3's Avatar
Porschetech3
The PIWIS will "FORCE" the SAI test and set the readiness flag...
The DME actually doesn't do the SAI test when cold , it waits untill the engine is fully warmed up and a lot of conditions are met, then it does the SAI Test at idle at a red-light ...( sorta randomly ..lol )
Old Jun 8, 2026 | 01:15 PM
Siberian14's Avatar
Siberian14
Exclamation
CA tests to see if SAI works?
Slakker says SAI not really needed and can be eliminated in any of their engine builds. Brandon said leave it off, just plug a few holes and be done with it.
Maybe call Brandon @ Slakker and ask his expertise on what to do? Lucky for me and millions of others, we don't have to put up with CA fanaticism. JMO.
YMMV
Old Jun 8, 2026 | 05:38 PM
Dave Crellin
Thanks, guys. Another drive cycle done but not SAI check cleared. EVAP cleared. The guy with the PIWIS says that the "force" has limited success from his experience so I'm going to try another cycle before going that way and taking his time from his autoshop.
Fingers crossed
Old Jun 8, 2026 | 06:31 PM
Porschetech3
When you try to force the SAI Test with PIWIS it will tell you if all conditions are met. It will not run the Test if all conditions are not met ....And iirr it will tell you which conditions are not met ...
Old Jun 8, 2026 | 07:10 PM
binaryaudax's Avatar
binaryaudax
Fellow CA owner here... and I had the same issue. What drive cycle did you do exactly? I was having trouble getting SAI ready, and ended up following a very specific set of instructions (something like 20 mins under 45mph and 3000 rpm, then 15+ minutes at highway speed, but _not_ above 60 mph). When I did that specific process the SAI flipped to ready almost immediately. I'll see if I can dig up the specific cycle I followed...
Update: found this in another thread and it jives with my memory of what I did:
Start engine, let idle for approx. 2 min, 10 secs.
Accelerate to 20-30 MPH, Maintain steady speed for approx 3 min, 15 secs.
Accelerate to 40-60 MPH, Maintain steady speed for approx 15 mins.
Decelerate and come to a stop.
Idle in Neutral for 5 mins. (manual trans.)
During the drive cycle, do not exceed 3,000 rpm or 60 mph.
I remember reading elsewhere that it's important this is done on a stone-cold engine (i.e., let it sit overnight and then follow this procedure in the morning)
Old Jun 8, 2026 | 08:33 PM
Dave Crellin
Thanks - that's very close to what I was doing. The challenge here is getting a steady speed for time in SoCal traffic...
Old Jun 8, 2026 | 10:28 PM
binaryaudax
I hear you... I had to be very careful about the time of day I chose to do this, and luckily, I'm close to a toll road with light traffic during the day. But doing only 55mph (a safe margin under 60mph) on a toll road from San Juan to Newport really pissed off a lot of other drivers.
Old Jun 10, 2026 | 01:11 AM
Dave Crellin
So no joy today after another careful drive cycle, but something odd comes to mind, and could it possibly be related?
In rebuilding the motor a new coolant temp sensor was installed. The old one worked in that it showed the correct normal temperature on the dash gauge. However the new one does not, barely moving off cold, or the 100 mark. At the same time, my OBD scanner shows the coolant temperature at expected levels, around 185-190 degrees.
I understand that the 4-pin sensor runs two circuits. Could it possibly be that a faulty sensor is not giving the ECU what it needs to run the full set of SAI checks? I realize this is unlikely, but everything else seems perfect yet it just won't pass the SAI check.
Old Jun 10, 2026 | 01:49 AM
JohnCA58's Avatar
JohnCA58
You might check your engine coolant temp sensor (ECT) and your intake air sensor (IAT), they must be within 11 degrees of each other during cold start up or it will never pass readiness test.
Old Jun 10, 2026 | 08:02 PM
Dave Crellin
This is really starting to bug me now. Stone cold start, followed cycle as best I could given LA roads. Will try again late night when roads clearer but this is ridiculous.
Old Jun 10, 2026 | 10:16 PM
De Jeeper's Avatar
De Jeeper
U can spend $200 for a laptop and pwis clone and force the test. Then u still have a good diagnostic tool on the shelf? Other then that just keep driving the car. At least u r not trying to trip the emisions on a minivan. 😀
Old Jun 11, 2026 | 01:30 AM
Otto Bonn's Avatar
Otto Bonn
I replaced my coolant temperature sensor chasing an unrelated problem from yours but it was similarly faulty. It would eventually come up but it was bugging me so I replaced it with an OEM sensor that works just like the old one that I originally replaced before installing the faulty one. Good news is it's very easy to do. I tilted up the passenger side to limit losing the coolant. Really not necessary and there wasn't much. Only just a little, less than an ounce or two. I captured it because I was wondering how much I would need to replace but it wasn't at all significant. Just have the new one ready and get it in place quickly. Some people talk about draining the whole system and what not. Forget that, just unscrew the old one and pop the new one in.
Also, for what it was worth, the original was fine, the faulty one didn't seem to affect anything, and the new OEM unit is now working just like the original.
Old Jun 12, 2026 | 03:53 AM
996.solo2's Avatar
996.solo2
Had to deal with this SAI problem when I was living in SoCal. Funny enough, the day I had an appointment to bring the car to an indy for the PIWIS scan/work, the CEL was gone when I started the car. Before that, I tried doing the "proper" drive cycles, following the steps to a T. No luck. Just kept driving it anyway. Light disappeared by itself after several drives, city and highway.
Long story short, it's just the drive cycles. ECU wants to see all conditions before CEL goes away. Drive it as much as you can and it'll clear itself.
Old Jun 13, 2026 | 09:35 PM
Dave Crellin
Finally! The case cleared the SAI check this morning, and a fresh smog certificate and license tags are now in hand. A new OEM temp sensor made a difference perhaps, but a number of drives finally got it over the line. I was sure the engine was fine, esp having checked the O2 sensor responses, and finally it cleared
thanks all for your contributions, and note I can go run the motor in and enjoy
