ipod
I finally joined the 21st century and bought an ipod
My cab has the bose high end stereo option (w/ the sub in the passenger foot well)
How do I hook this thing up direct to the head unit or othewise?
I thought I had seen this discussed here in the past but could not find exactly this when I did a search
Thanks for any help
Thanks for any help
raclaims: Which brand did you have?
I'm using the Griffin Tunecast II FM transmitter and it seems to work OK. But I haven't used it extensively. My commute is only 15 minutes so not much need for 1000's of songs.
Hey Jason, been a while! We just got a FM modulator for about $20 that has not 2...but 4 stations to choose from. All of the 2 station ones we tried had interference. There is also one that is made specifically for the iPod (forgot the name but it is at Best Buy) that runs $99. That one includes a mount, charger, and station choosing. Yes, you can choose any station since you can dial it in on the mount digitally. If you use the middle of the FM range your saound will be best.
raclaims,
you will have much better success with a hardwired FM modulator, as based on your description it sounds as though you were using a wireless FM modulator (iTrip, etc). A wired FM modulator (installed between the FM antenna and the antenna input on the headunit) will not suffer the 'free channel' problem you are describing.
There is a very detailed post (pics and instructions) over in the Cayenne forum, posted initially by the moderator (mudman2) regarding the installation of a wired FM modulator.
Lewis,
You are correct that I was using the Griffin iTrip wireless model. Thanks for the info...I really appreciate it as I do not have a cd changer and was hoping all along to use the ipod.
By the way, I just got back from London and saw a ton of 996s...although for some reason the steering wheel was on the wrong side
Here's how to get near CD quality sound w/ the iPod / iTrip Wireless FM transmitter by griffin technologies (no affiliation, just a good solution)
This is what i'm using:
EQUIPMENT:
3G ipod 40gig
iTrip for docking ipods
CDR-23 on a 2003 Boxster S with BOSE Digital Sound
SETTINGS:
CDR-23 Settings:
Bass: 0 to +5 (depending on personal preference / music)
Treble: 0 to +5 (depending on personal preference / music)
Balance: 0 (neutral - dont know why anyone would use otherwise...)
Fader: +3 to front (symbol ' /| ' )
AP: On - (unless you are parked in which case it gets louder and louder sensing its own sound and interpreting it as noise (talk about a design flaw))
Volume: Averages around +15-20 depending on song. (30 if i'm driving by a busy street with lots of pedestrians, so as to impress everyone with my wonderful taste in music )
(and... as before)
ipod Settings:
Soundcheck: On
EQ: ON
EQ Preset: Loudness
Volume: 60-75% (depending on various factors including: song, personal preference, interference)
iTrip Settings:
Frequency: 87.9 FM (lowest that the CDR-23 goes, but i know there are lower US FM frequencies, for example our Mercedes S class goes down to 87.5... if anyone knows how to make the CDR-23 go lower, do tell)
Led: Off (for less battery usage, i can't believe griffin technology dares to claim that the iTrip's batt usage is 'negligible', i found that the itrip, even with LED off, shaves 8 hours off the ipod's play time...)
I found with these settings, you can extract the best sound out of the already limited starting point of the iTrip FM modulator, also, as this device leeches about 50% of the ipod's power, it is my suggestion that you get a car charger for the device.
mabye someday, someone can invent some sort of CD adaptor, a la the tape adaptors of the early 90s
and on a final note, i hear becker is working hard on an analog input adaptor that can be implemented on the MOST bus network. (but i'm guessing it will take at least a year to two before we see a finished product)...
-Tom
EQUIPMENT:
3G ipod 40gig
SETTINGS:
CDR-23 Settings:
(and... as before)
ipod Settings:
Soundcheck: On
EQ: ON
EQ Preset: Loudness
iTrip Settings:
-Tom
Longtime ipod user here. I tried various FM transmitters in my previous car and the results were mixed at best. My 911 has an alpine head unit (with much better sound imho) that allows an aux in. It's a pleasure. Even better would be to control the ipod through the steering wheel (a la bmw). To me that's secondary.
good news for EQU - alpine will be releasing two ipod accessories in the future
one headunit that directly interfaces with the ipod, and also a adaptor that allows current AInet compatible alpine units to interface with the ipod
meaning display/browse through alpine head unit and control fo the ipod frmo head unit.
wonderful news!
too bad those of us with 03s-and after models are stuck with the useless MOST bus that won't allow an aftermarket peripheral to utilize the car's speakers / amp
wonderful news!
If you do not mind swapping out the head unit, Alpine is introducing a new "box" which will allow you to hook up any AI net head unit to your ipod. it will show playlist, song, artist...everything you can see on you ipod. It will also charge your ipod. and it allows for the cd-changer as well. The ipod box costs $100 and will be available in september. I am making the switch - along with new focal speakers and audison amps. I am having the ipod docking cable mounted in the arm rest so it doesn't clutter the dash.
