996 Forum 1999-2005
Light stays on
Old Aug 3, 2025 | 01:20 AM
AZ996C2Cab's Avatar
AZ996C2Cab
2nd Gear
Default Light stays on
Hello, I recently purchased a 03 C2 Cab. This evening after a drive I noticed a small orange / yellow light that stayed on after I shut the car off. I checked the car again after about 20 minutes and the light is still on. I don’t know if it’s always been on and I never noticed it, or did I turn something on and can figure out how to turn it off. The light is coming from a small light in the over head light cluster where the top locks into place. Any help is appreciated.
Old Aug 3, 2025 | 09:57 AM
CigarMike's Avatar
CigarMike
What AI Says:
An orange light in the overhead console of your 2003 Porsche Carrera Cabriolet most likely indicates a
warning related to the convertible top system.
Here's why and what you should consider:
  • Convertible Top Malfunctions: Many Porsche owners report issues with the convertible top system in the 996 generation (which includes your 2003 Carrera Cabriolet), according to JustAnswer and Facebook posts. Common problems include:
    • Hydraulic Fluid Issues: Low fluid levels or leaks in the hydraulic system that operates the convertible top can trigger warnings.
    • Sensor Faults: Sensors that monitor the convertible top's position can malfunction or go out of sync, leading to warning lights. One owner mentioned a faulty sensor in the triangular piece by the windshield as the cause of their convertible top not moving, costing $300 to fix.
    • Mechanical Obstructions or Misalignment: The convertible top mechanism can sometimes get jammed or misaligned, which the system will detect and trigger a warning.
  • Next Steps:
    1. Consult your owner's manual: The manual should provide specific details about the meaning of the orange light and the recommended course of action.
    2. Check the convertible top: Look for any obvious signs of issues such as leaks, unusual noises during operation, or if the top isn't retracting or extending properly.
    3. Seek Professional Diagnosis: Given the complexity of convertible top systems and the potential for electrical faults, it's best to have your vehicle inspected by a qualified Porsche technician. They can diagnose the exact cause of the warning light using specialized equipment and perform necessary repairs or recalibrations.
Important Note: While orange or yellow warning lights usually indicate a need for attention soon, red lights often signal critical problems requiring immediate action. If you see a blinking check engine light, this also indicates a serious emission-related issue requiring immediate professional attention.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
