996 Forum 1999-2005
Interior Lamp Issues: Potential Short?
Old Mar 10, 2025 | 03:13 PM
04_996_C2's Avatar
04_996_C2
Default Interior Lamp Issues: Potential Short?
Greetings:
I was replacing my interior lamps (map lights / courtesy lights) and, post bulb replacement, I have an issue. While the center toggle works as intended, as does the driver's side toggle, now the passenger side toggle (for map/courtesy light) will turn on all interior lights in one position, and do absolutely nothing for other positions. Point in fact, the passenger side bulb remains on constantly. I had to pull the bulb just to get some peace.
I checked the fuse but it was fine. Still I replaced it with a new 15A.
Has anyone else run into this issue?
Thank you!
Old Mar 10, 2025 | 03:23 PM
DBJoe996's Avatar
DBJoe996
Are you using LED bulbs? They have a polarity, work one way and don't work the other way. Perhaps you have them mixed. I would suggest doing one at a time, i.e., insert one bulb and see if it works correctly. Remove bulb and move on to the next one. BTW, LED bulbs are a nice upgrade.
Old Mar 10, 2025 | 03:26 PM
04_996_C2's Avatar
04_996_C2
Yes! I did replace with LEDs but I thought I had it sorted because originally they wouldn't come on at all and just hotted up real good (incidentally, I am not sure how the plastic light covers don't melt with the factory incandescent. I have a nice festoon shaped burn on my thumb and forefinger from trying to remove the driver-side door bulb).
I'll double check here, shortly. Thank you!
Old Mar 10, 2025 | 11:41 PM
04_996_C2's Avatar
04_996_C2
Sadly reseating the LED and even switching it out proved to have no effect :/
