Which CD changer?
Which CD changer?
Will the Becker Silverstone work with the PCM1?
http://www.caraudiodirect.co.uk/prod...roducts_id=169
Also, I heard that there is Sony that will work with it. Can anyone tell me what one it is?
I take it that the CD changer will come with the correct cable to plug it straight in.
Thanks,
Matt
Thanks,
Matt
The Becker unit you want is 2660 and it comes with the cable. The 7860 is the replacement. It is smaller and not a direct fit on the Porsche mounting bracket. Horst on the Becker board said the 7860 does not work well with PCM1 due to a memory loss.
We cannot get new 2660 units in the US because it has been discontinued. Try on the UK Boxster board boxa.net as they have found a source for the 2660 in the UK.
Whilst doing a search for the CD changer I stumbled across this JVC changer that says it has a Becker connection and will play MP3s. May be worth checking out?
http://www.caraudiodiscount.com/acat..._changers.html
I have a factory CDC3 that coming up for sale real soon. PM me if you're interested. It's from an 02 so it should work with non most setups. Not 100% sure about PCM compatability.
Porsche CDR-22 head units (Becker)..
Plays all 12 CD's via the head unit and
plays back MP3's, shows track numbers not ID3 tags.
Interesting...
ThunderC4S
