996 Forum 1999-2005
Calipers bolt
Old Jun 15, 2024 | 02:08 PM
Clueless11's Avatar
Clueless11
7th Gear
Default Calipers bolt
I had the old style hex bolts. 7 came off but one was so stubborn I now have an inside strip (the interior hex “socket” on the head of the bolt is now rounded sufficiently my hex bit rotates).
What now? Any suggestions?
Old Jun 15, 2024 | 05:11 PM
evoroadster's Avatar
evoroadster
Easy Out Bolt Extractor.
Amazon Amazon
Old Jun 15, 2024 | 06:25 PM
Christoph Soltau's Avatar
Christoph Soltau
Find a torx bit that is just just too big to fit and hammer that in.
Old Jun 15, 2024 | 06:52 PM
JTT's Avatar
JTT
^^ THIS ^^
Old Jun 15, 2024 | 10:02 PM
theprf's Avatar
theprf
Yes this.
If it doesn't work drill the head off. Remove the caliper. Unscrew the remnants with a pipe wrench.
Old Jun 15, 2024 | 11:10 PM
wdb's Avatar
wdb
Originally Posted by theprf
Yes this.
Or saw it off?
Old Jun 16, 2024 | 01:02 PM
Clueless11's Avatar
Clueless11
7th Gear
Originally Posted by wdb
Or saw it off?
that is not possible as the bolt is recessed in a countersink on the caliper.
i tired an M12 torx but it didn’t bite and I think made things worse.
wondering about using propane to weld something to the bolt before going the drill route?
Old Jun 16, 2024 | 01:08 PM
De Jeeper's Avatar
De Jeeper
Drill it. Just get a few new drill bits. The only way u will be able to get in there and weld anything is gonna be with a tig.
Old Jun 16, 2024 | 02:12 PM
Marv's Avatar
Marv
You should replace caliper bolts with new whenever they are pulled. That's probably a bit ****, but every other time is probably good.
Also, a quality socket for high-torque bolts is not a bad idea.
Old Jun 17, 2024 | 10:23 AM
Viper1000's Avatar
Viper1000
I have the same situation with a header bolt I snapped off recently. Just the head came off but not sure how I can get the rest out without having a nut head welded onto it.....which means bringing it in to a service place......for now I can run it the way it is but will eventually need to fix.
Old Jun 17, 2024 | 02:25 PM
Clueless11's Avatar
Clueless11
7th Gear
carbide bits? I tried another one of the bolts in a vise to see what I was getting myself into and with titanium it seemed like it was gonna be very challenging. Any other tips?
Old Jun 17, 2024 | 02:54 PM
Mike Murphy's Avatar
Mike Murphy
I think Porsche might even recommend new caliper bolts when they are removed and not to reuse them.
Old Jun 17, 2024 | 02:59 PM
De Jeeper's Avatar
De Jeeper
i would start with a 3/16 bit then 1/4, 5/16, 3/8, 7/16, 1/2. U get the idea...step it up slowly. U only have to go in about a 1/2' to get to the base of the head. Control the drill speed and use oil for lube. It takes some patients but its works.
Caliper bolts r just regular steel not titanium. I use cobalt drill bits.....carbide is for masonary.
Old Jun 17, 2024 | 08:17 PM
theprf's Avatar
theprf
Don't use carbide in a hand drill. It's very tough and very brittle. Like Aaron said start small with a 1/8th and step it up from there in small increments. The bolts are hard, they aren't excessively hard.
Don't use harbor freight drills, they are not sharpened correctly. Or the Amazon chinese no-name brands. Get a good set of drill bits from a US company and use those.
Old Jun 18, 2024 | 01:45 PM
Atgani's Avatar
Atgani
That's because they're elastic/stretch bolts.
Use off the shelf cap head bolts (grade 10.9 or 12.9) with a new/decent driver piece, and those suckers will outlast every set of pads and rotors you can ever throw at them. Just make sure you use aluminium paste on the threads and reduce the torque setting accordingly.
