Comfort Window Drop
3rd Gear
Comfort Window Drop
2001 996 Cab: Passenger window does not drop when using either the inside or outside handles. Double horn beep when unlocking. No horn beep when locking. Code comes up is 47. The window goes fully up and down via the console switch no problem. After a bit of reading through all the great threads here and in other places, thought I would add another and read more thoughts. After enough staring at / observation of the door and related parts (I have not taken the door card off yet), I have the following. The door card light (bottom right) does not come on when this door is opened. When I give the area by the latch (at the door, not body of car) a good Fonzie smack, 2 out of 3 times the window will drop the 10mm it should. Sometimes it will go down and back up real quick. Point is, a gentle whack by the black latching mechanism has an effect. Sticky microswitch? Maybe a switch needing some repair or lubrication? I don't see any other way to get at it except for removing the door card. Hoping to not open a can of worms and create other issues for myself.
Thank you for your input!
Received 1,921 Likes
2001 996 Cab: Passenger window does not drop when using either the inside or outside handles. Double horn beep when unlocking. No horn beep when locking. Code comes up is 47. After a bit of reading through all the great threads here and in other places, thought I would add another and read more thoughts. After enough staring at / observation of the door and related parts (I have not taken the door card off yet), I have the following. The door card light (bottom right) does not come on when this door is opened. When I give the area by the latch (at the door, not body of car) a good Fonzie smack, 2 out of 3 times the window will drop the 10mm it should. Sometimes it will go down and back up real quick. Point is, a gentle whack by the black latching mechanism has an effect. Sticky microswitch? Maybe a switch needing some repair or lubrication? I don't see any other way to get at it except for removing the door card. Hoping to not open a can of worms and create other issues for myself.
If you slightly pull on inside or outside handle without door opening, the window should drop. I have noticed if regulator is bad you can still hear the window motor turn for a second but window doesn’t move. So if no noise from motor check your micro switch on door handles, if you hear motor check your regulator. The latch also has a switch to keep window dropped when open and to move window up when closed. If you are jarring a stuck switch in the latch with the door open it may drop. When you open either door both door lights should turn on, so if light turns on when you open the other door it would seem you at least need a new latch.
3rd Gear
Drivers side door open = lights on, passenger side door open = no lights on.
Regarding the motor, I hear nothing when I lightly pull either interior or exterior handles.
Probably a faulty microswitch within the latching mechanism (actuator) and fix is to replace the entire actuator. Do you agree?
Dumb question: Is passenger considered 'left'?
Received 1,198 Likes
Watch out...US/Canada cars passenger side is "right". ROW cars (right hand drive) passenger side is "left". I had to replace my door latch actuator. Got a brand new Porsche door latch actuator and it has worked fine.
@CapeCoral944 , thanks for the detailed thoughts.
I wouldn't say RoW equals RHD (or RHD equals RoW, for that matter)...
wdb (05-24-2024)
I always assumed "RoW" meant "everything other than North American spec" but after doing a bit of digging it appears that it can mean different things depending on where it is being referenced; for example RoW might mean something different in the UK than it does in North America. So as not to overtax my feeble brain however, I'm sticking with my original assumption.
Also the airbag light hasn’t been mentioned yet. If you disconnect the airbag with the battery connected, you will get a warning light that must be reset with a scan tool.
wdb (05-27-2024)
