996 Forum 1999-2005
Early 996 Cabriolet Clamshell Gearbox Repair
Old 04-29-2024, 10:27 PM
davesly
davesly's Avatar
Default Early 996 Cabriolet Clamshell Gearbox Repair
If your clamshell motor just spins and your clamshell won't open (or close) then it is likely that your drive motor shaft has come disconnected from the clamshell motor gear drive. You can purchase these repair kits on eBay or Amazon for around $60. I made a short Youtube video on how to install that kit.
Installation video for the Porsche Clamshell Motor Gearbox repair kit#99656167301
You will likely need a female square socket of size 9/32. I purchased the following one on Amazon. You will need to grind down that socket so that it fits in the drive mechanism to hold the square shaft so that you can remove the allen bolt holding the shaft in. NOTE: The allen bolt is REVERSE THREADS. Turn clockwise to remove it.
https://youtu.be/fu2hOEP1YBI?si=sY63Sxmbs2h98Ena
Mayouko 11PCS 3/8" Drive SAE Pipe Plug Socket Set, Tapered Male Square Drive, Chamfered Female Square Drive, CR-MO
The following 2 users liked this post by davesly:
bbboomer67 (04-30-2024), Woodman71 (04-30-2024)
