996 Forum 1999-2005
What's this noise??
Old 04-22-2024 | 10:41 AM
NewbieFromNY's Avatar
NewbieFromNY
I'll do a complete video today. Really thanks everyone for your help.
When you step on the gas the sound does go away. And when you shut the engine off it appears faster.
Old 04-22-2024 | 12:37 PM
tommelton's Avatar
tommelton
Please include in the new video, the sound once the engine is off, since you say the sound seems faster then.
-Tom
Old 04-22-2024 | 01:30 PM
NewbieFromNY
How's this video
Old 04-22-2024 | 10:14 PM
KC-CarGuy's Avatar
KC-CarGuy
Did you find / solve the noise? ....
Old 04-22-2024 | 10:39 PM
NewbieFromNY
I did not.
Old 04-24-2024 | 10:13 AM
NewbieFromNY
-Tom
any ideas??
Old 04-24-2024 | 10:21 AM
NewbieFromNY
-Tom
any ideas??
Old 04-24-2024 | 11:20 AM
Mike Murphy's Avatar
Mike Murphy
It sounds to me like some metal part or even a hose is touching another part and simply vibrating. I would keep listening for the general area where it’s coming from, and start putting your hand in there (while the engine has been
off and cold from the day before) and just feel around for anything loose or touching any other parts.
Have you taken off the serpentine belt yet? If the noise goes away after removing the belt, then that’s a clue.
You can also remove the air box for a much better view, and will help inspect other areas, such as motor mounts.
With the engine off and on a flat surface, try putting the car in 3rd gear and rocking it back and forth to elicit the noise.
The more I listen to the noise, the more it sounds like the same frequency of every exhaust pulse. Could be a loose cat or loose exhaust tip.
Old 04-24-2024 | 11:30 AM
hbdunn's Avatar
hbdunn
Originally Posted by NewbieFromNY
any ideas??
Did you run it with the belt off?
Old 04-24-2024 | 11:52 AM
e30rapidic's Avatar
e30rapidic
Loose spark plug?
Did you run with the belt off?
Can you tap around the engine when its cold to see if anything is loose?
Lastly, what's your oil pressure? I doubt that's relevant to this though.
Old 05-17-2024 | 06:35 PM
NewbieFromNY
Ok. Sorry for the delay in the update. Life gets in the way sometimes.
It was a loose bracket off the muffler that I tightened and all good.
Dodged that bullet.
The following 2 users liked this post by NewbieFromNY:
996love (05-18-2024), Mike Murphy (05-17-2024)
Old 05-17-2024 | 06:38 PM
KC-CarGuy's Avatar
KC-CarGuy
I had the same thing happen with my exhaust. I heard an odd rattling... a clamp had loosened on the exaust. .
Old 05-17-2024 | 09:28 PM
Mike Murphy
Dodged that bullet.
Good to know!
Quick Reply: What's this noise??
