Will they fit or is the offset to large
Tgr rears wont really work. They r for a widebody.
Yes they will but the rears will stick out from the wheel wells. Stock for a C4 rear is ET65. I used a 15mm spacer with mine (making them ET50) and they were flush so a ET45 will stick out 5mm. Front will be fine
@Viper1000 that ET65 (-15mm for spacer) is on a 10" wheel though. The OP is asking about 11" so it'll stick out another half inch (~12-13mm).
Technically it "fits," but it's not going to look right unless you get some serious negative camber and lower it.
I'm running 997 wheels which are 11" wide in the rears with a 295/30/19 & ET 51 and they just barely stick out...maybe 1/4 inch. Haven't touched the camber at all (yet) and it looks and rides fine
