Update to this. I found the larger Bose amp. For reference in UK RHD cars it's in the wheel well. Good news is that this is probably the best location for the new amp. Bad news is as my new amp is wide/tall I'll have to cut the frunk base to do it. Before that I'll test the wiring connectors first to check that I've got
Just noticing your amplifier has the BLUE connector. I assume this is a Cabriolet? Are you planning on splicing the cables or sourcing a wire harness for the factory ISO connectors?
Mines a coupe, definitely not a cab. I’m planning on using the factory cables and splicing into it.
The only speaker I can’t find the output for is the rear sub. I suspect that there’s a 2nd amp somewhere for it, either the small one on top of the fuel tank or in the lower centre console. Hopefully the former as it will make using it much easier 🤞
