Tell Me This Is Safe - Engine Hoist Tab
So I recently dropped my engine and now I need to ship it to my builder. I’ve got to hoist it up off the ground and onto a pallet.
I’ve lifted the same engine before by attaching two lifting points on the aluminum crossmember that mounts to the engine mounts and the third point being at the hoist hook.
I’ve heard people say multiple times that it’s safe to lift the engine by that mounting tab, but as I dig in a bit more, it seems that that tab is just there as a support, when removing the transmission, and was not necessarily intended to support the entire weight of the engine, conversely, I’ve read that the reason it’s located where it is it so that it could support the engine and transmission and that is the center balance point.
I find the whole thing really sketchy and hard to believe since on the M 96 engine it is only held by two small bolts mounted vertically into the block. On a couple of the other engine variance at least one of the bolts goes into the block horizontally, which provides more strength.
Can anyone say with authority that this is indeed a safe, lifting point in the bolts aren’t going to pull out?
Yes, I have lifted hundreds of them with just that lift point, none broken...
The following 4 users liked this post by Porschetech3:
Yogibara (02-19-2024)
It's fine, done it many times.
BTW that picture is a 996 Turbo engine.
Yep - it's a photo from the web, but the hook/loop thingy looks the same.
No idea on the type of aluminum or threads. Skip - do you know? I searched and am not finding answers.
I know the Alusil blocks are very simular to Reynolds 390 Aluminum and is Hypereutectic through out, and is very hard and costly to machine, wearing out bits and tooling. The Lokasil blocks are only Hypereutectic on the bores and the rest is low-silicone Aluminum .
Porsche has been increasingly using Aluminum bolts also for weight savings... AFAIK there is no table for tensil strengths of Aluminum bolts either...or there various alloys...
I remember being in a training class On the Cheyenne/Panamera engines and they were showing the "new redesgned light-weight cam phasers", the had reduced the weight in various areas and used aluminum bolts to hold it together.. Porsche was very proud of saving a few grams of weight here......When I held it in my hand a big knot came up in my stomach, this didn't seem like a good idea to me to use aluminum bolts here...Sure enough, the bolts started failing and all were recalled..
The Aluminum material used in the M96/7 engines was discussed in the P10W Training classes back in the day, but the exact alloy name-number wasn't given.
Thanks for the info Skip.
Yep, the 4 bolts that hold it together..... I still have a few of the heads of the bolts in my tool box as momento's...lol
It wasn't just the Cheyenne and Panamera either back in 2010, the aluminum cam bolts found it's way into GT3's also....
Assumed parent material ultimate tensile strength (UTS): 42,000 psi
Shear strength : 0.6 x UTS = 25,200 psi
Thread engagement length: 0.2" (about 4 threads, conservative based on reference doc)
Max load per threaded hole: 1400 lbs
I would be more worried about the lifting lug failing, honestly.
Porschetech3 (02-20-2024)
I have a spreadsheet I made that is imperial but a 5/16"-18 thread is very close to the M8 x 1.25 thread that the lifting point uses.
