Nav System, NVA-N751A
Hi
I recently purchased a '99 C2. It came equipped with an Alpine navigation system, NVA-N751A. I have no need for the system, and am thinking of removing it. Is there a market for these where I can sell it?
A related question. The '99 C2 that I bought came with the Alpine navigation system with a (TME M00-65A) display mounted under the dash just in front of the shifter. I am told this is an aftermarket installation.
When I moved the display to install a B&M short shift kit, I found that whatever was there originally had been hacked and hewed so the display would fit in. I have no need for the nav system as I much prefer using maps (when I get lost). I want to remove it and replace it with whatever went there originally.
Any idea what part(s) would go in there?
Is that the new Becker Monza?? Have any pictures with it on?? I just sold my complete Eclipse Nav system on Ebay, so I'm looking into getting one of those beauties..
I posted a thread on the Becker Monza when I had it installed:
https://rennlist.com/forums/showthre...t=becker+monza
That whole section with slots (cupholders?) and cubby-hole. Looks like the skeleton that was left behind. I'm going to assume it's an available part to put back in when I take the nav system out!!!!
The top holds CDs (4 of them) and the cubby-hole holds whatever. That's the original configuration but you can put whatever you want in there. For example, I replaced the CD holder with a police scanner. If you want to bring it back to how it was, your best bet is to purchase the parts from a dismantler. Here are two you can try:
http://www.911pcar.com
http://www.partsheaven.com
I recommend trying the latter first. If they don't have it, then the former, and then eBay, and then lastly a dealer. That is of course, unless money is not a big issue.
