In development: Modern instrument cluster display for 996.1
Coop's temp gauge had me thinking on this prior, I think a round LCD screen could fit over/outside the center gauge without fully obstructing the tach, or you could get one big enough to fill the gauge completely and do tach in software. The tilt of the plastic may make it a bit wonky, but if the viewing angle works on the screen it seems possible. You'd have to integrate it into something that would press fit around the cluster, but the aluminum gauge trim pieces you can buy are an example of how this looks good in general. If the exterior .1 and .2 dash dimensions are the same then that makes life easier, and it would be a reversible install which wouldn't require actually cracking open the cluster. A small (~1.28 inch watch face) screen could possibly fit right in the middle without obstructing either the tach or the original screen.
The floating screen in the below thread still looks like the best bet for getting a large amount of screen space almost in vision while driving, and adding a companion screen in the cluster could be interesting alongside that. I feel like it should be possible to get some kind of floating screen setup without having to cut into the trim like the other install, something anchored to the hazard screw hole seems like it should work.
https://rennlist.com/forums/996-foru...-upgrades.html
Right after I get drive by wire, brake by wire, and throttle by wire on a 1999 C2.
https://comma.ai/
https://comma.ai/
Unsure, but doubtful... I doubt the market is very large (since it's 996.1 only) and wouldn't be a simple plug-and-play installation. End-user support would be the killer and not worth my time unless the price was very, very high, which would make it sell less. Most likely, I'll release all the details (code, PCB designs, 3d printed parts, etc.) as open-source once I'm happy with it and have actually tested it in my car.
No plans for those right now. The left one handles the odometer, and I don't want to mess with that (for resale value). The right one handles the oil level check, which I don't want to bother recreating. The center one only handles speed, which is easy to replicate, and the onboard computer (range, mileage, etc.), which is pretty much worthless (to me), so it made the most sense as the one to replace.
Currently, from the cluster. The cluster receives the analog signals from every sensor it displays. As far as I can tell, the cluster is on the K-line for diagnostics purposes, but not to receive any data from the DME.
Eventually, I'd prefer to fetch coolant temp from the DME so it's more accurate.
@binaryaudax
Email me at magnus@rejsa.nu if you want one of my small integrated ESP32 12V CAN boards with Kline (the v2.5)
https://github.com/MagnusThome/RejsaCAN-ESP32
Schematic
https://github.com/MagnusThome/RejsaCAN-ESP32/blob/main/Schematics/Schematic_RejsaCAN%20v2.5.png
I have a 996.1 GT3 myself and have been thinking to get oil temp visible someway but haven't got around to it yet. I'll keep the cluster original but had some ideas on how to show it on it.
Schematic
binaryaudax (12-21-2023)
@binaryaudax
Schematic
https://github.com/MagnusThome/Rejsa...CAN%20v2.5.png
Schematic
I made a spot on the board for the option to solder on a SN65HVD100 on the rear of the board in addition to the SN65HVD230 that is on the top side of the board for CAN. But I haven't gotten around to fiddling with the LIN/Kline stuff yet.
The following 2 users liked this post by MagnusT:
binaryaudax (12-21-2023),
wdb (12-21-2023)
@MagnusT coudl you use one of the can boards as a can sniffer the try and decode the AC control module? The standard 996.2 HVAC controls suck and I want to see if the controls can be reverse engineered to work on a separate interface like the Grayhill canbus modules etc
www.savvycan.com
aussiegman (01-01-2024)
- Connect to K-line to read additional OBD2 data (intake air temp, codes, etc.)
- Create a menu system that can be navigated with the 4th stalk for the OEM OBC, or use the clock button on the cluster to cycle through different screens.
If everything works, one high-value thing that race dashes offer over OEMs is programmable limits (alarms). If oil temp goes over say 275F, water temp over 200F, etc. Bringing info to attention instead of having to scan the gauges is just objectively better.
The following 3 users liked this post by circuit.heart:
These two tasks alone sound like the biggest fish to fry, but will be so freaking cool when pulled off. Watching it done on E30's has me bracing for impact though (either labor hours or cost).
Porschetech3 (12-22-2023)
