Cam's 99 build/documentation thread
996love (06-02-2024)
#123
Do make sure that you feed the motor and not the wiring loom! And be prepared to see some arching as you're basically shorting the two wires till the motor starts turning. You could wire a 12V car bulb (21W brake light) in between that limits the current, not as great as a resistor but it should work.
But perhaps the easier and risk-minimized way would be to do step 7. If you get 12V on the DVM display for whatever short time (record a video with your phone, if you have no helper at hand) then you can do the following:
-switch off ignition
-connect the booster pump pig tail to the wiring loom
-put your hand on the booster pump
-have a helper (doh...) turn on the ignition
-feel for the motor starts to turn.
Depending on how far you want to go, but these (used on BMW's) female terminals fit the male terminals of pressure sensor, booster pump (and others) exactly
https://www.realoem.com/bmw/enUS/partxref?q=61131368621
I don't know to which tyco or AMP type of terminal they cross reference to, unfortunately.
#124
Cant help ya with the issues but love seeing that you're getting it on track so much!
I might've missed it but are you swapping between street & track pads or are you just wearing them out?
Also, I didnt see a track mentioned but Im guessing you're hitting the Ridge and SIR? Bummed I never got a car on track while I lived up there...
#125
yeah im swapping pads pretty often, and yep the ridge and SIR!
another little upgrade i did today, gt3 air ducts
still havent fixed the psm issue though, but if feels good to get something done without issues
996love (06-08-2024)
#126
Ok so the psm is fixed! A fuse was missing. Since this started happening after taking it to a shop when my alternator was dying (which blew some fuses), i think one must have been misplaced or lost.
#127
Just fixed 2nd gear crunchiness I hope, by readjusted the numeric cables at the transmission end.I guess they stretched out over time? She's proper now, no codes and back on street pads, which is great because I'm moving into a new place with a public garage soon, and won't be able to do any work myself for a while.
