Cam's 99 build/documentation thread
#31
I got caught in a late snow storm this spring, car was fine while moving but once stopped,,, no-go.. I ended up turning back, going to a store and buying some nylon rope and made some red-neck tie chains.. Then made it home.
My BMW 330xi (06) was un-stoppable in anything less than 6" of snow. RIP
#33
No that is the toe bar. The lca is what the shock bolts to.
U could also unbolt the 2 uca's instead to allow the upright to swing down.
2mAn (09-15-2023)
#35
Nice! Congrats on getting it in. Pelican Parts generally had good DIY write ups, I actually just bought their 101 projects book so I can just keep it in the garage with the car. Not perfect but very helpful.
im approaching the end of the UAOS repair/ upgrade. Got about 2 weeks until I’m signed up to take my C2 to PECLA for their owner driver experience. No weekends free between now and then though so it will be a nailbiter to get it done in time
damage98MO (09-18-2023)
The following 2 users liked this post by cameronc56:
2mAn (09-15-2023),
#37
Cars looking good!
#38
Thanks! Looks like the back drooped down a little more, I'm happy with this for now- I might get some 10mm spacers and then keep the fitment this way until I'm ready for summer tires next season.
#39
The second autocross with this car went great, 8 seconds behind time of the day and I was on all seasons.
Yesterday I dropped the car off to repair the cv boot, and they found that the water pump was leaking so theyre fixing that while its on the lift.
heres what they showed me
and final update, my miatas listed for sale and im prepping the m3 next
2mAn (09-29-2023),
damage98MO (09-25-2023)
#40
Water temps been running a bit cooler now, put a few hundred miles on it this weekend
Also, I installed the numeric shifter + cables and have a few problems with it...
1. 3rd and 4th gear have significantly more play than 1/2/5/6, I wonder if I have adjusted the reverse cable at the transmission wrong..
2. shifting to 5/6th, the bolt head that you use to secure the lever to the rest of the assembly, hits the shift boot surround and jiggles the whole console. I'm going to see if this can be flipped around
3. 3rd gear has always been sometimes hard to get into, i really have to slam it in to guarantee it doesn't get stuck. I was hoping the numeric would help with this but it still happens. I wonder if changing fluid would help with this?
4. getting the rubber grommet or the rubber tubing installed was a pain in the *** and I gave up. Bad idea... its ridiculously loud now. I tried spraying insulating foam into the gap, but it didn't do much. I'm going to try getting the rubber grommet reinstalled, cover the grommet->shifter cable section in rubber tubing, and covering everything up in dynamat.
recouping costs lol
recouping costs lol
#41
If you have not changed the gear oil, you should definitely get it done. It certainly can't hurt. It's not exciting, and you can't see it, but it's a big important bit of maintenance. Change the fuel filter while you're at it
#42
Gear oil is almost as hot a topic as motor oil ! Many will argue use the Porsche OEM fluid . Made by Shell to Porsche specs it works great . I also have a 99 C4 and I used Motul in the transmission and front differential . My car has 150,000 miles and shifts butter smooth .
#43
Use spray lube or even dishwasher soap in that rubber shift cable grommet and it will slide right in. There should not be any contact or looseness with that cable so u got something adjusted poorly.
#44
https://www.summitracing.com/parts/MOB-122035-1
wdb (09-25-2023)
#45
The OEM fluid is Mobil Delvac. As an aside, it's the only fluid I use. I tried Motul and did not like the way the car shifted with it.
