More questions about moving to the frigid north
Maybe I'm really being paranoid but now I'm thinking that taking my Southern car with 100,000 mi on it to the north where it will be subjected to dry air and cold temperatures, then it might make sense to preemptively replace the fuel lines? Anything else that might become brittle I replaced all the suspension motor mount transmission mount, all the coolant lines are good I just had a major one replaced when I did the water pump and reservoir. But fuel lines? I have no idea if they were ever done, thoughts?
tia
tia
Check the windshield washer fluid. Some of the products are not safe for freezing environments. Not sure if frozen washer fluid would damage the reservoir or the hoses, but low temp fluid is available.
damage98MO (07-19-2023)
It was built in Germany they have lots of snowy mountains
no worries
I bought my 99 from the south all its life to NY I drive until they salt the roads 3 years no problem
no worries
The following 5 users liked this post by frank970:
cboxell (07-19-2023),
damage98MO (07-19-2023),
duuder (07-21-2023),
EVOMMM (07-19-2023),
Mike Murphy (07-20-2023)
Also with all the heat the south and west are enduring
I think that creates just as much if not more car damage
The following 2 users liked this post by EVOMMM:
Fracture (07-19-2023)
One of the last Corrados I restored was an original Florida car for 28 years - I was the 2nd owner. Every piece of plastic on that car was ready to crumble to bits when touched. Not one spot of rust on it though.
The Corrado I'm restoring now is a barn find from upstate New York that got parked after a head gasket blew. The plastics on it are in really good shape.
So cold is not always bad. Clean it regularly if it gets salted, don't idle it to warm up, and easy on the throttle for the first few minutes.
The only things my car complains about when it’s -10F outside are the bearings in the idler pulleys and the engine, unless I’m running 0w-40 for the winter. I would make consider a coolant flush if you haven’t had one in…forever. Are you storing your car in a garage? Also, if the battery is older than 5 years, consider a new battery.
Otherwise, you should be fine. Gasoline doesn’t freeze until -100F or so.
It will be garage parked, unheated tho. I'm considering block heater and blanket.
Mike Murphy (07-21-2023)
Received 1,921 Likes
That helps, thanks. She had new radiators, water pump, and reservoir this spring, so coolant is new. I run 5w50 tho here in NC.I guess change to 0w40 for winters? And I'll get antifreeze in the wiper washer fluid. Battery was new in spring '22, and it's kept on a tender. New alternator as well. I'm considering changing the y cable and starter, it's of unknown age. The big thing for me is rust proofing. I think I'll try woolwax or fluid film. Messy but better then corrosion.
You might find that an old beater with snow tires is cheaper than trying to winterize the Porsche.
