996 Forum 1999-2005
Do I have everything I need for water pump replacement project?
Old 06-27-2023 | 12:33 PM
gbarron's Avatar
gbarron
Originally Posted by steam_mill
Replace the plastic connector with the metal one.
This! Easy to do when you have the belt off and piece of mind!
996-CAB (06-27-2023)
Old 06-27-2023 | 02:19 PM
996-CAB's Avatar
996-CAB
You will also need distilled water to mix with the antifreeze. Do not use tap water. I used this in a recent water pump replacement: Joe Gibbs Racing Driven CSP Coolant System Protector (12oz Bottle) 50030 (lnengineering.com).
I also got the low temp, same as you, and it takes some getting used to since it slows down how fast the engine reaches operating temp, but you get used to it.
Old 06-27-2023 | 02:22 PM
996-CAB's Avatar
996-CAB
4Driver4, I am looking at the picture. I'm hoping the rubber grommets are stuck to the bottom of your air box, because they aren't here in the picture.
Old 06-27-2023 | 02:37 PM
Ben8jam's Avatar
Ben8jam
Yes, will mix with distilled 50/50.
Per operating temp, I'm doing this now to prepare for the 100F+ temps in summer - so hopefully it'll do just that !
Old 06-27-2023 | 07:25 PM
4Driver4's Avatar
4Driver4
Good eyes. Yes, they always seem to come out with the box. Not sure why...
Old 06-29-2023 | 07:19 PM
rechtien's Avatar
rechtien
Jake had commented previously on using a copper gasket spray on the WP gasket. It was debated and i cant find the post but i used it based on his recommendation and had zero leaks. His reasoning was he had seen more than one leak after a rebuild lead to failure. Good enough for him, good enough for me.
Vacuum fill, while nice, isnt necessary. Just be cautious filling. Use multiple cycles of running to temp and filling. Keep an eye on the reservior.
Watch the TQ on the idler pulley bolts. One is much lower than the other. I misread it and snapped a bolt in half.
Good luck. Hope you have small hands as it made the job much easier.
Ben8jam (06-29-2023)
Old 06-29-2023 | 09:46 PM
binaryaudax's Avatar
binaryaudax
Originally Posted by Ben8jam
Water line hard pipe (upgraded version) / Water line flexible pipe (upgraded version)
Do you have a '99?
The upgraded lines DID NOT fit on my '99. The kink at the top of the flexible hose doesn't align with the coolant tank. When you compare the coolant tank to later years you'll see that the connection point for the hose is set further back into the engine bay (about 1-1.5 inches) hence. The earlier flexible hose is straight and does not have a kink.
I ended up upgrading both pipes and the newer coolant tank. The newer tank is slightly larger which makes it a massive pain in the *** to install.
Old 06-30-2023 | 02:08 AM
Ben8jam's Avatar
Ben8jam
Originally Posted by binaryaudax
Do you have a '99?
Oh man, what? I thought the issue was the needing to upgrade the TWO hoses. After all my reading, I didn't know I had to update the tank too!
Old 06-30-2023 | 01:05 PM
theprf's Avatar
theprf
I use the copper spray on all MLS gaskets (except exhaust manifold gaskets). I don't trust them to seal little scrapes and divots as well as clayboard or paper gaskets.
Old 07-01-2023 | 10:45 AM
De Jeeper's Avatar
De Jeeper
U shouldnt need the mk2 tank.
Quick Reply: Do I have everything I need for water pump replacement project?
