Valet at hotel burnt my clutch 😡🤬
Yes, replace the RMS and IMS bearing while there. If you go the LN Engineering, make sure you or your tech register the bearing and return the one that comes out (applies to the Retrofit. Not sure requirements if you go with the solution.) Whatever you do, do not replace the old one with a sealed bearing, or you will be right back where you started. Let us know how it goes.
1alpha (06-25-2023)
The following 5 users liked this post by philbert996:
2mAn (06-26-2023),
Dr_Strangelove (06-26-2023),
Fracture (06-25-2023),
Muckesäckele (06-26-2023),
wdb (06-25-2023)
allcool (06-25-2023)
