Can't Install PCCM+ (settings men) 2002 w/ Bose (Non-MOST)
Guys,
Can you PLEASE help me? I'm now $500+ in wasted labor, and can't install my PCCM+. I've scoured every forum.
I have a 2002 996 Cabriolet with BOSE Audio, NON-MOST. It's THIS diagram for the wiring (below).
Got my PCCM+ and got the error where it won't allow me into the settings menu since it thinks I'm in motion.
Tried every which way of connecting the unit, can't get into the menu.
Local Porsche dealer has no clue. 2 local installers failed to figure out how to get in. Tried plugging in GPS, Mic, etc etc. Can't get past that menu.
Suncoast told me to ground Pin 18 for the DSP. Aside from reading everywhere else that it's pin 17, I told Suncoast (who I bought PCCM+ from) that I don't have a DSP..... My Bose Amp only has 8 pins.
So, now I'm massively in the hole on labor with no prospects of fixing this error. I never saw any resolution from others with this error other than dead threads or "it fixed itself."
Is the issue my hardware? This suuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuucks.
I do not have a PCCM+ nor have I ever touched one. That said the consensus is when it displays "in motion" when it is not in motion, it means the internal accelerometer is broken and the PCCM+ is defective.
Received 1,844 Likes
For what it's worth the M680 is the DSP amplifier from Porsche as noted in the attached schematic.
My PCCM turned on before I plugged in the GPS antenna and did the same thing. I unplugged it (removed the main power connector) and let it sit for about 30 min, When it restarted, it still gave me the warning intermittently. When it gave the motion warning, I figured out that if you hold any of the buttons for about 10 second, it'll allow you to get past the motion warning. I can't say if any of this will work for you but it did for me. Once I figured out it would allow me to get past the warnings by holding down any of the buttons like "settings" I followed the instructions in this post and disabled the warning all together.
https://rennlist.com/forums/996-foru...l#post17564478
This sucks.
This Porsche Classic program is a joke
