996 Forum 1999-2005
Tiptronic Fluid
Old May 18, 2023 | 10:50 AM
Kot911's Avatar
Kot911
Default Tiptronic Fluid
Hi,
What kind of transmission fluid should I buy to my Tiptronic?
996.2
Production:01.2003
Engine 3.6 320HP
Transmission code: A9610
Car from japan market.
This is Mercedes transsmission. On the sump is the number: A 772 270 15 12.
Old May 18, 2023 | 12:38 PM
theprf's Avatar
theprf
The fluid should be "Shell ATF 134".
Fluid can also be bought at Mercedes. Ask for fluid for a 2005 E55 AMG.
Old May 22, 2023 | 03:21 AM
Kot911's Avatar
Kot911
Thank you very much for the advice, it's really difficult to choose oil for this gearbox.
I found two Shell ATF 134.
One is:
Shell Spirax S6 ATF 134ME for 7G-tronic Mercedes-Benz (NAG2FE+), MB-approval 236.15
and the other one is:
Shell Spirax S6 ATF 134M "for 5 and 7 gear NAG2-V sport Mercedes Benz", MB-approval 236.14 and compatible with: MB236.1 and Mb236.10
I heard that many people use 7G oil to 5 gear transmission becouse its better. Which one fluid should i use?
Should I buy anything else besides oil, gasket and filter?
Old May 22, 2023 | 07:36 AM
cdk4219's Avatar
cdk4219
I have been using valvoline maxlife in my 722.6 transmissions for years.
Old May 22, 2023 | 01:29 PM
theprf's Avatar
theprf
Either of the two Shell fluids will work. The gearbox is called "5G tronic" or "NAG" by Mercedes.
Pentosin ATF-6 is recommended when the Shell fluid is not available.
